Micro800 & UDFB RA_PID
bbishop108
Mar 2017
Indiana
86
So I am using a Micro850 and I downloaded the RA_PID UDFB for tuning the temperature of my Thermocouples(TC). I am not sure if I am using enough of the options on the PID instruction or not.
Since I do not know how to paste pics on here, still kinda new here as well, here are the portions of the PID that I am using:
PV, which is my tank temp, SV, CVmax, CVmin, and LimitCV is set to true. So far this everything I am using, while in use I have noticed that the CV value takes a very long time to change after the temp reaches the SV. This leads me to believe that I do not have the PID configured correctly, as such I would greatly appreciate some assistance with configuring this instruction. Thanks
My company built a small test machine using a Micro800 PLC and CCW software. We chose the Micro800 because the machine is very simple. We are...
139
Hi, Is there a way to set the IP of a micro dynamically, based on a variable value.?
159
Anyone use the newer 2080-L50E or L70E with 1734 Point IO yet? I have a customer asking for a setup and I have not found anyone that has done...
371
Is there a way to download the program to a Rockwell Micro810 without using the Rockwell CCW application?
720
Hi All, I am having trouble converting a real to string and keep it to 2 decimal places. I'm sure its a simple solution. Any help is appreciated
275
