plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 6th, 2017, 04:19 PM   #1
Ronnie Sullivan
United Kingdom
Ronnie Sullivan is offline
Is it a world record?
7, 3 phase motors connected consecutively - all wrong direction.
They were wired in plain black wire (to be marked when connected)
And I was doing the panel end and another man doing the motor ends with no belling out.
I call the record at 7
Old December 6th, 2017, 04:33 PM   #2
the_msp
United Kingdom
the_msp is offline
the_msp's Avatar
You have a 50% chance of getting it right... and a 90% chance of getting it wrong...
__________________
Regards,
Patrick
https://www.youtube.com/user/MrMatrixEngineering
Old December 6th, 2017, 04:38 PM   #3
AustralIan
United Kingdom
AustralIan is online now
That should happen every 128 times you do that, on average.
Old December 6th, 2017, 04:46 PM   #4
Bering C Sparky
United States
Bering C Sparky is offline
Bering C Sparky's Avatar
They certainly seem to be backward more than they correct for sure......but 7 in a row....you should buy a lotto ticket, maybe your luck is due for a change about now.
BCS
__________________
Changes in Latitude = Changes in Attitude
*********Florida - Seattle - Alaska****************
"I WANT MY LOGIX BACK"
Old December 6th, 2017, 04:54 PM   #5
Ronnie Sullivan
United Kingdom
Someone said the exact same thing (lotto ticket)
I have had theory for years about motor direction.
If it is awkward or tight for room to change the wires, they will be wrong.
In the panel they were in the bottom terminals with about 50mm of room. I had to lay on my side using long nosed pliers to get them in
Old December 6th, 2017, 06:36 PM   #6
jraef
United States
jraef is offline
jraef's Avatar
Also, if there is an entire room full of VIPs watching you hook it up to see the new equipment run, the direction will be wrong and no matter how many times you explain that there is no simple way to tell in advance, you will still be the goat...
7 in a row though... that does beat my record of 5, on a machine that had 5 motors on it.
Old December 6th, 2017, 07:14 PM   #7
Aabeck
United States
Aabeck is offline
Aabeck's Avatar
When I install a line with many motors not VFD controlled I check the rotations and if the majority need reversed I reverse the incoming feed.
I had one customer that insisted the incoming feed had to be a certain rotation and I had to reverse almost 30 of the 35 motors on the line.
Old December 6th, 2017, 07:20 PM   #8
Dirt
Sweden
Dirt is offline
Well, even if you wire up all motors "correctly" but someone mixes the feeding phases somewhere.. Have had that happened before.
Old December 6th, 2017, 07:56 PM   #9
GaryS
United States
GaryS is offline
GaryS's Avatar
try one of these
http://www.aemc.com/products/html/mi...bname=products
they solve the motor rotation problem
Old December 7th, 2017, 12:58 AM   #10
Dirt
Sweden
Dirt is offline
Sometimes they even get the outgoing lines from a 650MW generator in the wrong order..
Old December 7th, 2017, 02:13 AM   #11
GaryS
United States
GaryS is offline
GaryS's Avatar
That must be from across the pond
Here is in the US large stations are all connected to the grid. There is a predefined sequence to the grid network. We don’t cross the wire over like that we sequencronise the generator to the line so everything always match. They constantly monitor it, if it get out by 1/2 hz they open the switch and isolate the generator otherwise it would take the grid down. Look at the great northeast blackout in mid 80's took a big chunk of the grid out due to 1 generator fault. Left most of the North East in the dark they didn't isolate it soon enough they learned their lesson and isolate them faster now.
Old December 7th, 2017, 02:13 AM   #12
Rob...
Supporting Member
United Kingdom
Rob... is offline
There's a good proportion of Englands distribution network that is the opposite rotation to the rest of the country.
A **** up that was made around the WW2 era, an now would simply cost to much to correct.
Old December 7th, 2017, 02:34 AM   #13
GaryS
United States
GaryS is offline
GaryS's Avatar
By the way I just had to through this out there
Most of the UK power is generated and disturbed. By PPL UK a homely owned company of PPL Global an US Base company headquartered here in Pennsylvania
That's probably the part that stays working
Old December 7th, 2017, 03:48 AM   #14
Saffa
New Zealand
Saffa is offline
I'm surprised anything works properly in the good ol US of A what with only 110VAC and that crazy imperial system.
Old December 7th, 2017, 05:21 AM   #15
Dirt
Sweden
Dirt is offline
Well you can't syncronize two phases swapped? Unless you can turn the rotor current in the opposite direction. I do not know the whole story from back in the day, this happened more than a decade before I was born.
Somewhere around 1/2Hz off will trip on my side of the pond as well. Of course this one is connected to the grid, like a large generator in the US.
This was a design fault made in the early 70s.. The grid is supposed to be one certain way (and is), like on your side of the pond. The problem here was that the designer of generator/breaker didn't take into account that it gets "mirrored" looking from one side compared from the other.
This is a very unique solution here, I haven't seen it anywhere else.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Disruption in the Automation World, and a practical PLC Code Generator to get started EdStevens LIVE PLC Questions And Answers 80 March 26th, 2017 08:40 AM
Great in the school world. new to the real world. peelseeds LIVE PLC Questions And Answers 9 March 22nd, 2012 07:31 AM
Plc World ghaffar3 LIVE PLC Questions And Answers 7 November 27th, 2006 10:14 AM
OT...World War 3? or the New World geniusintraining LIVE PLC Questions And Answers 5 July 20th, 2006 08:35 PM
World record Jezz LIVE PLC Questions And Answers 5 February 26th, 2004 01:46 AM
