Can't Add a controller to my project
timryder
Feb 2007
Macomb MI
176
So I have a machine that I'm building which will act as a slave to the Main PLC of the cell (1756-L85E ControlLogix). The PLC I am using is a compact logix 1769-L24ER, I have created some Produced and Consumed tags and a UDT which will be used for the interlocks between us, but when I try to add his PLC to my project as an EtherNet Node I can't see his controller type in my list. I went to rockwell and downloaded an EDS file for it and installed that but I still can't see it as an option to add.
What am I Doing wrong?
EDIT: I am using RSLogix 5000 Professional Edition v24.02
Have you tried filtering by "Controller" only?
I did a quick check in Studio 5000 v30 (I don't have v24 installed) and what you are trying to accomplish worked fine for me in v30
WAG - Is the L85E supported in V24?
I think Bob is right. I don't think the L8's were supported until V28.
I was recently trying to set up produced/consumed between an L8 & L7 and had to bring the L7 up to V28 before I could add the L8 to its tree.
I cannot get CCW to add a controller, i keep getting a error message saying that the device is not authorized. This happens with any model and...
1,361
When should a new battery be added to the Micrologix 1500? Should I wait until the low battery light comes on? Or should I just add it now? Will...
2,733
helllo. - I was created one project with Proficy machine Edition 7.0. On it I choice controller Series 90-70 PLC, my system PLC consits power...
6,889
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
114
I have just installed Studio 5000 V30.11 on my Windows 11 Pro machine. First I had an "Invalid Pointer" error that required me to update Factory...
115
