PlantPAX 3.5 FactoryTalk View ME
rootcon
Aug 2011
Western Mass
26
I have a P_AIn faceplate on the HMI. I also added the P_AIChan with the Cfg_AIChan object selected. When I try to navigate to the AIChan faceplate it will not properly resolve. Is there a P_AIChan global object or some other file I need to add?
In studio where you add the Global Objects Parameter, you need to fill out the 2nd box in order for that to work. (1st box is the tagname, 2nd box is the path) Then on the Engineering tab of the AIn faceplate you add the tagname of the AIChan object. When you click on the AIChan it takes the path (from the 2nd box) and the Tagname (from the engineering tab) and puts them together to open the AIChan faceplate.
Also, make sure that you have added the AIChan faceplate to the display objects.
Yeah I just got off the phone with Rockwell and that' s what they said to do with the #103 Global Parameter. It did not work. I ended up having to configure a new Globally Scoped Object in the PLC to get this to work as intended. The Tech support guy mentioned that sometimes it works and Sometimes it does not.
Hi folks, I'm beginning to pull my hair out over this so if someone could shed some light on what's going on I'd be grateful. We bought...
21
4,604
Hello, i need to use P_Intlk and feed the Status interlock OK bit to a P_DOut block. However, there's 17 interlocks for this output. How can I...
108
Hello All We have 3rd party vendors that run on older versions of PLC (Plc2.0) while we run the main system using plantpax and PLC 3.5-10. Plantpx...
88
Dear Members, Hello, we are working on a project and facing an issue with the plantpax 5 PMTR library, we have a bidirectional motor, which has 2...
236
The PMTR has a timeout parameter for run feedback during a start, but once the motor has been running for a while and loses that run feedback (to...
223
