plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 11th, 2017, 12:28 PM   #1
randy
Supporting Member
United States
randy is offline
Siemens 319 3PN/DP
I'm trying to setup the Ethernet port on a new 319 3-PN/DP.
I have the PG/PC Interface setup on "Ethernet Connection (2) I219-LM TCPIP Auto.1. I also have in the properties IE-PG Access Tab "Assign IP addresses unique to project" selected.*
Again just using the Siemens PG unit I can ping the PLC,* compare blocks, and go online with the program. If I select in the IE-PG Access Tab "Do not assign IP addresses automatically" I lose all communication.
Using my standard laptop I cannot ping the PLC. The PLC is an update from a 315 2-DP to a 319 3-PN/DP.
-Randy
Old December 11th, 2017, 01:17 PM   #2
mk42
United States
mk42 is offline
-Randy
You didn't specifically include a question, but I assume you'd like an explanation, and help connecting with your standard laptop.
If I recall, "Assign IP addresses unique to project" is used to give your laptop an extra IP address in the correct subnet, if your PC's IP settings wouldn't allow for communication with the PLC.
questions:
1) What IP addresses are assigned to each device (Laptop 1, laptop 2, PLC)
2) Are you connecting directly, or via switches?
3) I'm assuming the PG has TIA Portal. Does your standard laptop have any version of Step 7 on it, or are you only looking for pinging?
Old December 11th, 2017, 01:32 PM   #3
randy
Supporting Member
United States
randy is offline
I apologize for the structure of the question.
PLC = IP 17.16.20.2 Subnet Mask: 255.255.255.224
Laptop Siemens PG = IP 17.16.20.100 Subnet Mask: 255.255.255.224
Standard Laptop = IP 17.16.20.200 Subnet Mask: 255.255.255.224
Yes the PG has TIA, but I'm using Manager Classic 5.6
No the Standard Laptop does not have any Siemens software.
-Randy
Old December 11th, 2017, 01:35 PM   #4
randy
Supporting Member
United States
randy is offline
Also when I use the Edit Ethernet node it see the MAC address and I assign a IP and the subnet mask all goes well.
I have not had a problem assigning a IP address
Old December 11th, 2017, 02:45 PM   #5
Lare
Finland
Lare is offline
with subnet mask 255.255.255.224 you IPs should be between 17.16.20.1 -17.16.20.31?
Old December 11th, 2017, 02:56 PM   #6
randy
Supporting Member
United States
randy is offline
Do you mean the PLC or my laptop in regards to the IP address?
-Randy
Old December 11th, 2017, 03:02 PM   #7
Lare
Finland
Lare is offline
All IPs. If you have subnet 255.255.255.224, you have limited IP range to 30 devices, all devices needs to be on that range.
You can check http://www.subnet-calculator.com/
Leave PLC to IP .2, change laptops somewhere between 1.31 (something like 11 and 12).
Then check with ping command, it should work if there is no firewall softwares.
Old December 11th, 2017, 04:34 PM   #8
randy
Supporting Member
United States
randy is offline
Thanks for the help.
It works
-Randy
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
AdvancedHMI - Siemens PLCs S7-200/1200/300/400 Beta drivers BryanG LIVE PLC Questions And Answers 25 December 3rd, 2013 03:21 AM
Siemens to Allen Bradley sweetjohnny LIVE PLC Questions And Answers 4 April 20th, 2013 02:46 AM
Connecting to Siemens 319 PLC jackhenkel LIVE PLC Questions And Answers 6 July 30th, 2012 01:31 PM
Siemens 505 to Siemens S7 Rob S. LIVE PLC Questions And Answers 5 July 10th, 2012 08:37 PM
Transfer Data From Siemens PLC to AB PLC Danocane LIVE PLC Questions And Answers 8 September 7th, 2007 07:29 AM
