plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 8th, 2017, 11:34 AM   #1
suboliu
Canada
suboliu is offline
siemens 1200 Block Move
Hello everyone.
I have question on using Siemens PLC 1200 for Data Block move.
The question is: I have 30 words, like MW20---MW29
MW30---MW39
MW40---MW49
I would like to move these Words Block to MW100--MW109
when condition=1, move MW20---MW29 to MW100--MW109
when condition=2, move MW30---MW39 to MW100--MW109
when condition=3, move MW40---MW49 to MW100--MW109
because 1200 doesn't like 200 that it have BLKMOVE_W instruction,
1200 has MOVE_BLK instruction, but it only moves in global DB move, if so, how can I move MW20---MW29 to global DB? and then How can move global DB to MW100--MW109?
Thanks!
Old December 8th, 2017, 12:23 PM   #2
dwoodlock
United States
dwoodlock is offline
dwoodlock's Avatar
I have used the block move extensively, but its always from DB to DB. Your system may not allow this, but my basic suggestion would be to try and use DB's for the majority data storage if you can.
When I was intro'd to the 1200 series the Siemens rep. basically told us that if we're using MW's we were programming the "old way", and the newer systems are better suited to deal with DB's. This could totally be BS, but I just adapted.
Old December 8th, 2017, 12:49 PM   #3
mk42
United States
mk42 is offline
Dwoodlock has it on the nose. Everything I've seen implies the 1200 pretty much only has the M memory/Global Memory for legacy purposes. It has many many disadvantages compared to DBs, and not much in the way of advantages. You really should be trying to use DBs if you can, or else you'll be missing some capabilities, like complex data types (arrays for Move_Blk).
Old December 8th, 2017, 12:54 PM   #4
L D[AR2,P#0.0]
United Kingdom
L D[AR2,P#0.0] is offline
Do you have access to SCL?
Old December 8th, 2017, 01:11 PM   #5
L D[AR2,P#0.0]
United Kingdom
Example:
Old December 8th, 2017, 01:58 PM   #6
suboliu
Canada
suboliu is offline
Quote:
I will Try!
Old December 8th, 2017, 03:24 PM   #7
suboliu
Canada
suboliu is offline
Example:
I am not familiar with SLC. can use LAD to do this?
Old December 8th, 2017, 04:29 PM   #8
boneless
United States
boneless is offline
No, there is no easy way to do a for loop in ladder.
You could look at STL and indirect addressing tho. But the above example is the absolute easiest.
Al the code you need is right there
Old December 9th, 2017, 11:33 AM   #9
mk42
United States
mk42 is offline
Quote:
1200 doesn't support STL, thank God.
Old December 9th, 2017, 12:01 PM   #10
boneless
United States
boneless is offline
You are absolutely right!
I'm a dingus, sorry about that.
Old December 10th, 2017, 07:22 AM   #11
BryanG
United Kingdom
BryanG is offline
POKE_BLK means you don't need the loop. The attached lets you POKE between various areas, DBs must be non-optimised.
Old December 11th, 2017, 10:50 AM   #12
suboliu
Canada
suboliu is offline
Quote:
Thank you very much!
I have another question,
If I create a global DB, like DB1, Can I use tag DB1.DBX0.0, DB1.DBB0, DB1.DBW0,etc. because I need change words value through HMI, if I use above tags to change DB1 value?
if can't, then I only MW10, MW20 ..... absolute address, but if there is too many words and need move global DB, How can I do for these?
Old December 11th, 2017, 03:09 PM   #13
mk42
United States
mk42 is offline
I don't think I quite understood what you're looking to do.
If you are looking to access a bit out of a WORD length tag in the PLC, look at slice based addressing: (eg TagName.x0).
Are you trying to do indirect addressing in the HMI? Are you trying to declare HMI tags for overlapping bits, bytes, and words? I think you can do what you need to do if you set the DB for standard access (turn off Optimized access in the properties of the DB).
If your question is simply "can I access tags in the DB from the HMI" then the answer is "yes". If it is a Siemens HMI, then you can probably use Optimized or Standard. If it is a third party HMI, then you probably need Standard access.
Old December 11th, 2017, 03:18 PM   #14
kalabdel
Canada
kalabdel is offline
Thank you mk42 for saying what I avoided to say.
suboliu, show us what you're doing. Describe as detail as possible, use screen shots and specify the equipment and software you're dealing with.
With regard to absolute addressing and non-optimized blocks, I personally avoid them and only recall using poke only once. The way of the future with Siemens is symbolic addressing and though sometimes it feels like going around in circles to achieve something very simple I got used to it and it pays when creating reusable code.
Old December 11th, 2017, 08:00 PM   #15
suboliu
Canada
suboliu is offline
Thank you very much, I didn't describe clearly, see attach for my questions
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advice Needed - Siemens from Rockwell move cardosocea LIVE PLC Questions And Answers 7 March 23rd, 2017 11:43 AM
S7 1200 function block pauly LIVE PLC Questions And Answers 3 November 14th, 2013 04:12 PM
What is Data Block in Siemens S7? Riche Robledo LIVE PLC Questions And Answers 6 September 26th, 2011 04:36 AM
Siemens Ratio_P block in CFC ry_fern LIVE PLC Questions And Answers 6 March 26th, 2010 08:44 AM
Siemens and Initialization when Entering a Function Block Andrew Evenson LIVE PLC Questions And Answers 3 April 16th, 2005 12:55 PM
