plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 8th, 2017, 02:28 PM   #1
PLBoudette
United States
PLBoudette is offline
AB Micro850 communications issues
I'm trying to connect to a AB Micro 850 controller and am having issues. This is my first time trying to program one. I plugged in a USB cable to the USB port but nothing happened. It's my understanding that a "Found New Hardware" box should appear to install the drivers. I tried all my other USB ports but still nothing. Then I got another USB cable and tried that with all of the USB ports. Still nothing. I tried using a null modem cable with a 1761-CBL-PM02 cable in the serial port, setting up a DF1 driver but still nothing. Finally I connected a crossover cable to the ethernet port, set up my PC static IP to 169.254.100.200 with subnet 255.255.0.0 (as advised per another help thread) and scanned with the ethernet/IP driver. Nothing. And not only nothing, I don't even get the green link LED to come on when there is a good link connection. Am I still doing something wrong? Or did I just get a bad controller? The power light is green and the FAULT and MS lights are flashing red, which I assume is a fault because there is no program loaded. All help is appreciated. Thanks.
Old December 8th, 2017, 02:58 PM   #2
A_G
United States
A_G is offline
I've never used a AB Micro 850 but I think you need to use Connected Components Workbench (CCW) to set up communications to it. Open CCW, then go to the Communications tab, then Configure Drivers. Choose the driver you need under Available Driver Types. My guess is you need to set up a Virtual Backplane driver but not 100% sure. Hope this helps.
Old December 9th, 2017, 07:00 AM   #3
geniusintraining
United States
geniusintraining is offline
geniusintraining's Avatar
On a 850 or 820 you can just use Ethernet, they are default dynamic so your router will send it a IP address and using RSLinx you will see it once you setup your driver... then in your project just set the IP address to what your router set it to
__________________
www.PLCCable.com PLC Communication Cables, PLC Trainers, Fluke Meters, MicroLogix, ControlLogix, Siemens, Allen Bradley and more... all your automation needs... ((NEW)) After Market 1784-U2DHP Allen Bradley USB to DH+ and Gateways
Old December 10th, 2017, 09:57 AM   #4
stn99nts
Canada
stn99nts is offline
1. Reboot your laptop.
2. Plug into the USB port on the 850.
3. The "found new hardware" box should pop up, let it do its thing. Once finished, you should see the 850 under the USB driver in RSLinx.
4. If "found new hardware" doesn't pop up, open RSLinx anyways and check to make sure the 850 isn't there already for whatever reason.
5. If none of these work, try a different laptop and make sure you're not using a bad cable.
Also, try the ethernet port using a regular patch cable, rather than a crossover.
Old December 11th, 2017, 07:23 AM   #5
PLBoudette
United States
Thanks for the replies. Unfortunately none of the suggestions helped. I tried connecting both to a router but it didn't see the controller. The link light still doesn't come on. I tried rebooting the laptop and using all the USB ports with 2 different cables. Still nothing. Tried using a regular patch cable. No luck. I think I might just have a bad controller.
Old December 11th, 2017, 09:29 AM   #6
geniusintraining
United States
Most newer laptops have auto switching so a crossover Ethernet cable or a straight will not make a difference so either should work
I dont know if there is a hardware reset on the Micro800's but thats what you need to look for... some sort of reset to factory default
Was this a new or used PLC, any chance someone was trying to update the firmware? and failed
Other then that you now have a plastic brick
__________________
Old December 11th, 2017, 07:04 PM   #7
Firejo
United States
Firejo is offline
Firejo's Avatar
Are you running RSLinx?
__________________
Go Hawks!!!
Old December 12th, 2017, 07:51 AM   #8
JordanCClark
United States
JordanCClark is offline
JordanCClark's Avatar
It's going to sound stupid, but was the USB cable fully inserted? The ports seem to be tight (not necessarily a bad thing), and sometimes require a bit more effort to plug and unplug.
__________________
_____________________________
Jordan
Any man that can hitch the length and breadth of the Galaxy, rough it, slum it, struggle against terrible odds, win through and still know where his towel is, is clearly a man to be reckoned with.
-- Hitchhiker's Guide to the Galaxy
Old December 12th, 2017, 10:08 AM   #9
PLBoudette
United States
So thanks for all the suggestions. We finally found the problem. It turns out that the controller needs a full 24V for the communications to work. We have an adjustable power supply in the shop and it was set at 12V instead of 24V. So the power indicator light was on and the fault lights were flashing, however the comms wouldn't work. So all is working correctly now. Chalk another one up to human error.
Old December 12th, 2017, 11:22 AM   #10
geniusintraining
United States
Thanks for letting us know!
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
AB Micro850 Socket TCP communication HM-Systems LIVE PLC Questions And Answers 0 July 14th, 2017 04:20 AM
AB MICRO850 PLC shift register joetavormina LIVE PLC Questions And Answers 1 December 22nd, 2016 07:54 AM
AB PowerFlex400 & Scadapack32 communications cire3621 LIVE PLC Questions And Answers 13 June 6th, 2010 02:09 AM
Direct communications with AB PLC's jrpisci LIVE PLC Questions And Answers 5 September 19th, 2006 04:46 PM
AB Analog issues XtremeIN LIVE PLC Questions And Answers 5 September 11th, 2006 05:17 PM
