plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 11th, 2017, 06:04 PM   #1
khaledgenidy
United States
khaledgenidy is offline
khaledgenidy's Avatar
CompactLOgix L32E Unkown IPaddress please help!
Hi All,
I am new to PLC, i am using Allen Bradley.
My issue here is that one of the company's old coworkers setup an ip address for the plc but with no IPAddress labeled
whenever i use BOOTP/DHCP Server:
1- It always shows me 3 different Ethernet address (How to know Which is the PC and which is the PLC?)
2- It always shows me the type is DHCP (Does it matter if its on DHCP or BOOTP?)
3- Main question is (Is there any way i could know the IP address for that CompactLogix L32E?)
I want to start a small project and looking forward someone to guide me to know these three answers.
Thanks,
Old December 11th, 2017, 06:16 PM   #2
undr_the_table
United States
undr_the_table is offline
undr_the_table's Avatar
start with opening RSLinxs classic and see if it detects your plc(make sure the Ethernet IP driver is configured first)
For starting off I would recommend to statically assign an IP address rather than dynamically just make sure not to take something else's IP address on the network.
Old December 11th, 2017, 09:19 PM   #3
stn99nts
Canada
stn99nts is offline
Quote:
You can match the IP address to the MAC address that shows up beside it in BOOTP/DHCP (XX-XX-XX-XX-XX-XX). I think the MAC address on an L32 is under the battery cover, on the side of the unit.
If you don't feel like pulling the processor off the rack, open RSLinx and configure an ethernet driver to contain all three addresses that you see popping up. Once RSLinx starts browsing, it should tell you which is which.
Old December 11th, 2017, 09:29 PM   #4
Ken Roach
United States
Ken Roach is offline
Ken Roach's Avatar
Welcome to the PLCTalk forum community !
Because the controller also has an RS-232 serial port, you can connect to that with a 1756-CP3 cable (or any other null-modem cable) and use the DF1 Full Duplex driver in RSLinx Classic to "drill down" to the Ethernet port object.
That will allow you to read or write the IP address for the controller.
In general, CompactLogix L32E controllers MAC ID's begin with 00:00:BC:xx:xx:xx, if you want to keep trying the DHCP utility.
Old December 11th, 2017, 09:30 PM   #5
backendcode
Canada
backendcode is offline
You should be able to look IP address besides your Mac address in Bootp software, and then you can change the IP address of your computer.
The best option will be, as you are using compact logix, you should be able to get online using USB cable (AB USB cable used in a printer) and then you can right-click on the processor and assign the IP address and then try with the ethernet cable.
Let me know if you have any question,
thank you
__________________
Junior Control Engineer
Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live
Old December 12th, 2017, 12:38 AM   #6
dmroeder
United States
dmroeder is offline
dmroeder's Avatar
thank you
The L32E doesn't have a USB port, it has a serial port as Ken mentioned
Old December 12th, 2017, 07:07 AM   #7
janner_10
Supporting Member
United Kingdom
janner_10 is offline
Quote:
The youth of today have it far too easy!!
Old December 12th, 2017, 07:32 PM   #8
backendcode
Canada
Sorry for the wrong information I didn't check that
Thank you for correcting me
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Compactlogix L32E to DF1 Radio Modem OkiePC LIVE PLC Questions And Answers 3 March 22nd, 2017 07:44 AM
Compactlogix L32E Ethernet communications Trex LIVE PLC Questions And Answers 3 December 29th, 2014 11:53 AM
Problem Changing IP addresses of Compactlogix L32E and Panelview 1000 Hamburgers LIVE PLC Questions And Answers 5 June 30th, 2014 12:35 PM
comm between SLC 5/04 and Compactlogix L32e zz12z LIVE PLC Questions And Answers 7 June 7th, 2014 06:57 PM
Compactlogix L32E series B MikeUK LIVE PLC Questions And Answers 2 December 15th, 2013 07:09 PM
