Rockwell PLC's with Serial Ports
cardosocea
Nov 2016
Fields of corn
2,632
Hello gents,
I have an application where the cheapest communication link available is a radio telemetry system that works off of RS-232 protocol.
Our site only uses AB and looking into their catalog, it seems like there isn't many options for PLC's with Serial ports.
Do you guys still use them or how can I get around this? For one or two of the applications, a sort of gateway PLC would be feasible to collect all the data required from the installation (consisting of multiple PLCs) and sending it over the link. But on remote systems that have only one PLC, having a separate one just for a serial port is a bit of a waste.
Any ideas? I know there's some sort of Serial Port converters out there, but I personally prefer to have all enclosed as much as possible.
We build custom cables for a Maxon radio, one of our customers uses the Maxon SD-174EL
I have never used them but this customer is very good so I'm sure they would only be using quality products they are also a member here so they maybe able to help further
We have some older systems we integrate to on RS232
We use a Point IO™ Module - RS232 Interface - 1734-232ASC
Seems to work well.
Seems to work well.
+1 for the 1734-232ASC
There are also products from Prosoft that we have positive experience with.
Prosoft Rockwell In-Chassis
Of course, there is the single port available on some PLC-5 and L6 and earlier ControlLogix processors.
Hello all, I am trying to communicate to a brushed DC motor controller through a 1769-ASCII to a RS485/TTL serial adapter. Part numbers for each...
1,475
I would like to make a small discussion about ways of reading out serial number of PLC Rack in RSLogix. I know only about one way of doing it...
3,984
Hello Guys, I am using 1769-L36ERMS PLC by Rockwell which doesn't let me MOV or COP literal text into string datatype? i very well know the...
390
Hi all. This is a very specific issue. My first time with a Modbus ProSoft. Customer setup doesn't make any sense but we're stuck with it...
366
See code at the bottom. Hi all. For the story, this is my first complete project using a Rockwell PLC, I've been mostly working with Unity Pro...
790
