plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 13th, 2017, 12:15 PM   #1
beckysue
Supporting Member
United States
beckysue is offline
Crimson 3.0 Emulator: 64 bit machine?
Any updates on running the Emulator on a 64 bit machine? It works about 20% of the time for me, otherwise I get an error message, sometimes different ones, each time I try and download to the emulator.
Old December 13th, 2017, 01:24 PM   #2
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
I run the emulator all the time on a win64 machine. About 1 in 1000 times, I will see an error which results in me having to go into services and stop g3sim.exe
99% of the time when sending updates to the emulator, it will hang, I wait 3 seconds, click abort, send again and it works. This has been going on for many years, but since it is only a 3 second delay, I just learned to work around it.
I have not seen the Visual Studio error you have pictured that I recall.
I am running Windows 7 Pro 64 bit and Crimson build 700.00
Sidenote: Red Lion has infomred me that there are no plans to implement the emulator in Crimson 3.1 to which I basically responded BOOOO! I love the emulator even with its quirks.
__________________
It's not all the variables I am most concerned with, it's the undiscovered constants.
Old December 13th, 2017, 01:34 PM   #3
beckysue
Supporting Member
United States
beckysue is offline
Thumbs up
Thank you, I also use the "wait, abort and send again" method but was just wondering if there was something I could do to fix that quirk. I've found that if I leave the emulator window open, it sends more reliably as well.
Another silly thing I've spent a day trying to figure out: I'd like the text on a data tag (flag tag) to flash when on, and stay steady when off. I've found how to do the flashing on the fill, but I want the fill to remain transparent. Any suggestions?
Old December 13th, 2017, 01:51 PM   #4
Steve Etter
United States
Steve Etter is offline
Steve Etter's Avatar
I have NEVER been able to get the emulator to work. I always get the Just-In-Time Debugger error. No idea how to fix it, either.
Old December 13th, 2017, 05:58 PM   #5
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
Quote:
What build of Crimson? What PC OS are you using?
Sure, just set the text color to flashing (on the object, not at the tag properties). Use the tag value as the enable for the flash properties.
__________________
Old December 14th, 2017, 06:49 AM   #6
Steve Etter
United States
Quote:
Build 694.000 and Win7 Enterprise, SP1, 64-Bit
Old December 14th, 2017, 08:59 AM   #7
Steve Etter
United States
Ok. I "think" I've figured out my problem anyway. It has to do with using the Driver: "Allen-Bradley Native Tags via L5K file Enhanced"
Before I begin, though, I downloaded and installed Build 702.004. Same problems. Emulator doesn't work. So...
I started with a new project and set it up with a single rectangle with no data. Emulator worked.
I added "Data" to the rectangle and created an ethernet communications path using my "normal" AB L5K file Enhanced driver and imported an L5K file I had saved earlier. I then assigned a tag to the "Data" in the rectangle. Emulator did not work. Same error I have been seeing all along.
I modified the communications to use the AB L5K file (not Enhanced), imported the L5K file again and the tag. Emulator worked.
This makes me believe the Emulator simply can't handle the AB "Enhanced" driver for some reason.
Until I get more clarification, I guess I will have to stop using the Enhanced driver or not use the Emulator.
Sorry to have hijacked this thread....
Steve
Old December 14th, 2017, 11:21 AM   #8
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
Do you have your emulator ports mapped to the proper PC ports? I have not used the emulator with a Logix5K processor in quite some time, and I don't remember which driver I was using but it did work and did communicate with the real PLC as long as I set up the emulator ports properly.
__________________
Old December 14th, 2017, 12:04 PM   #9
Steve Etter
United States
Yes, I did. That was one of the things I noticed when I began working with the other drivers. The TCP Port it was successful on was 789 while the Enhanced driver defaulted to 44818. I changed the Enhanced to the 789.
Old December 15th, 2017, 08:59 PM   #10
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
Well I think RSLinx uses port 44818, so if you are online with the PLC using RSLinx, then a port conflict might be hosing up the emulator. I am not sure if you can change the port number for the L5K Enhanced driver in Crimson and have it succeed but I suppose it is worth trying. Or, try shutting down RSLinx and see it it will run... I am just making guesses here...
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Red Lion Crimson 3.0 and J1939 CAN=> HELP! Brian@HCI LIVE PLC Questions And Answers 2 December 7th, 2016 10:51 AM
Need some Crimson 3.0 help! AMoore LIVE PLC Questions And Answers 0 December 3rd, 2015 10:21 AM
Crimson 3.0 emulator talking to RS Logix 500 emulator radfahrer LIVE PLC Questions And Answers 0 March 23rd, 2015 02:56 PM
Crimson 3.0 and I/O above 15 Bullzi LIVE PLC Questions And Answers 3 December 5th, 2012 12:14 AM
Crimson 3.0 elementary question tommy23t LIVE PLC Questions And Answers 3 May 29th, 2011 02:15 PM
