Alarm/Horn Combination Unit - IP67
rajy2r
Nov 2006
Canada
167
I am looking for an Alarm/Horn Combination unit that will work in a steam environment (i suppose IP67 rated). Has anyone used something like this before.
Typically the issue with a combo unit is the holes for the horn let steam in and then it starts to rust.
I found the unit below, that should work i suppose, but hoping for something prettier.
http://www.e2s.com/system/1/product/pdf/13258/mca112-l1-alarm-sounder-led-beacon-datasheet.pdf
Would appreciate the help.
Thanks for the Info Guys. Most of the stuff is IP65/66 which doesn't seem to work in a steam environment. I have tried the Federal Signal SL600 and they don't last.
So far i have only found the Banner KL50, which is 50MM and is IP67 with the sealed light and horn, but i am hoping i can find something a little bigger for visibility purpose as this is for an outside application and not for a conveyor application.
Hello All, Can anyone recommend a panel mounted Alarm Sounder that is not annoying? I am not having much luck asking the Google Machine, so I...
2,148
I have an application where we want to install a PV+ in a control room. My question is there a version that has an alarm horn that triggers off...
2,400
Looking to silence an alarm from a HMI Button. Right now the HMI button command is set to Pulse the binary bit. Will the attached logic work to...
9,434
I'm a newbie who started a job as a repair tech recently. I've had plenty of luck with ABBs, Allen Bradleys, and a few others, but I can't seem to...
26
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
72
