plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 14th, 2017, 11:44 AM   #1
mcmenomy8
United States
mcmenomy8 is offline
Celsius to Fahrenheit
I'm using a Mitsubishi PLC with GT Designer3 and GX Works 3 and I am trying to create a switch that will change my numerical display between celsius and fahrenheit. I'm a beginner at this and am having troubling figuring out how this is done. Please help.
Old December 14th, 2017, 11:50 AM   #2
alive15
United States
alive15 is offline
Create two rungs in your logic. One rung has your switch "on" input. The 2nd rung has your switch "off" input. Have two outputs created that display Celsius and Fahrenheit. Put one output on each rung to be displayed.
Old December 14th, 2017, 12:40 PM   #3
boneless
United States
boneless is offline
Quick tip. Remember that there is a different scaling for absolute setpoints and relative setpoints.
If you use hysteresis or deadbands in your program, remember to scale these accordingly .
Yes I know this by experience
Old December 14th, 2017, 12:40 PM   #4
mcmenomy8
United States
So, where do I program in the equation that will make the numerical display switch?
Old December 14th, 2017, 12:42 PM   #5
AndOsk
Sweden
AndOsk is offline
Mitsubishi PLC
First you will need to know the input from the tempsensor. is it using a INT as input amount. In wich range can the sensor go from. You will need to define what type of sensor it is. When you know what the values mean then you can try and convert them to either Celcius or Fahrenheit.
Post me if you need any more help.
Old December 14th, 2017, 01:48 PM   #6
janner_10
Supporting Member
United Kingdom
janner_10 is offline
Stick to whatever your used to in PLC calcs (I assume it's F if you're from USA) and just display something different on the screen with a C / F button.
Old December 14th, 2017, 05:55 PM   #7
AustralIan
United Kingdom
AustralIan is offline
Have a button for C and a button for F. If they hit the F button, tell them no, either passive aggressively or with a popup that explains the benefits of standardisation.
Old December 15th, 2017, 01:52 AM   #8
janner_10
Supporting Member
United Kingdom
Quote:
Or just a pop up which says 'It's not 1950!"
Old December 15th, 2017, 02:06 AM   #9
Ronnie Sullivan
United Kingdom
Ronnie Sullivan is offline
He's a beginner folks.
In the PLC program, you have to get the value from your temperature probe and convert that to either F or C.
You then have to use an equation ie MUL D100 K9 D101 DIV D101 K5 D102 etc to change it to the other.
You will then have both values in 2 separate registers
How you display these on the HMI is up to you
Old December 15th, 2017, 09:03 AM   #10
mcmenomy8
United States
Thanks guys, I got it figured out. My customer wants to be able to display Fahrenheit. Celsius would be just fine with me. But I have to do what the customer is paying for. So thank for the help.
Old December 15th, 2017, 09:22 AM   #11
alive15
United States
alive15 is offline
Set the HMI with two push buttons, one Celsius and one Fahrenheit, place the HMI on a pool table, and hire Ronnie Sullivan to select whichever button you want by hitting the cue ball into the button.
May want to have a couple HMIs on hand for back-up in case the first one breaks.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Converting a Logic File from Degrees Celsius to Fahrenheit tkessler8 LIVE PLC Questions And Answers 18 April 7th, 2017 06:01 AM
Controller that operates below zero celsius klikopc LIVE PLC Questions And Answers 10 March 4th, 2010 01:52 PM
Converting fahrenheit to celsius Cajunman0821 LIVE PLC Questions And Answers 1 May 8th, 2004 03:37 PM
