plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 14th, 2017, 02:39 PM   #1
bright676
United States
bright676 is offline
2711-k6c5l1 PanelView 600 to Ethernet?
I have a old PanelView standard 600 I plan on using in my garage for setting up security.
The garage is about 60 feet from the house SLC-500 and 5/04. I have a 2711-NC22 cable that needs be about another 20 feet longer at least..
What would be a good solution to get it to work? Can I get a longer serial cable? Or what do I need to get it to communicate on Ethernet?
Thank you
Old December 14th, 2017, 03:00 PM   #2
Ken Roach
United States
Ken Roach is offline
Ken Roach's Avatar
The 2711-K6C5L1 terminal has an RS-232 port that runs DH485 protocol.
You could connect it to an SLC-5/04 with a straight-through RS-232 serial cable, for which the typical maximum length is 50 feet.
I've run low-capacitance cable with RS-232 signals for about 200 feet with good success. 60 or 70 feet isn't stretching the 50-foot limit of RS-232 by very much.
There is no practical way to connect this terminal to Ethernet. There are a couple of *impractical* ways, with network gateways, but those are far too expensive for a home rig.
Old December 14th, 2017, 03:11 PM   #3
Mickey
United States
Mickey is offline
Mickey's Avatar
Your PV supports DH485 protocol.
Your 2711-NC22 cable will not work, the round port on your SLC5/04 is DH+ protocol and cannot be changed to DH485.
You will have to use the 9 pin serial port on the SLC5/04 configured for DH485 protocol.
60 feet should not be a problem. A 2711-NC14 is the proper cable ( its just a straight thru cable, make your own)
Edit: Ken types faster.
__________________
Mickey
If you want happiness for an hour-take a nap. If you want happiness for a day-go fishing. If you want happiness for a month-getmarried. If you want happiness for a year-inherit a fortune. If you want happiness for a lifetime-help someone else.
----- Chinese Proverb
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Panelview 7 Communicatios Ethernet IP josecarias LIVE PLC Questions And Answers 1 December 13th, 2017 11:12 AM
PanelView Plus ---> SLC L551 Ethernet Communication Issues celichi LIVE PLC Questions And Answers 17 May 3rd, 2016 12:40 PM
PanelView Plus 600 Compact to ML 1400 Comms PLBoudette LIVE PLC Questions And Answers 3 July 11th, 2012 08:19 AM
Communication problems between Panelview 600 and Flexlogix jackstein LIVE PLC Questions And Answers 4 July 25th, 2011 04:31 PM
5/04 with DH+ Panelview 1400E onto Ethernet sledford LIVE PLC Questions And Answers 9 October 13th, 2003 12:31 AM
