![]() ![]() ![]() ![]() This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() ![]() Join Date: Oct 2012
factory talk activation expired
I have an ex employee laptop which has rslogix 5000 software and it has the factory talk expired. When I try to look up the activation it does not show in the directory. Would rockwell be able to tell me what this is? I generally remote in to a computer that has RSlogix where I access PLC programs and such. I need this laptop to communicate with a standalone machine which uses a compact logix brick. I just want to pull the programs off of this machine.
To explain my dilemma a little further. We went through a downturn so I am back in the saddle, but with no IT support etc. I am having a hard time finding the license locations of logix software along with WW etc. Any other way around the activation? |
#2 |
In general that means that it was a temporary activation, most likely a Toolkit subscription. Or, since it doesn't show up in the FactoryTalk Activation Manager as a *.LIC file on the computer, it may have been activated by an Activation Server that has a permanent or annual license activation. Search thoroughly on your computer for *.LIC text files. On my PC, they're in the path C:\Users\Public\Documents\Rockwell Automation\Activations In general, your local distributor can help you unravel what the licenses sold to and maintained by your company are, and help get you set up with the appropriate licenses. When RSLogix 5000 is freshly installed (or activated by being connected to a network with a license server), it will then run for a week in "grace period" mode while it's disconnected from the server.
__________________
- "Simpler is better, except when complicated looks really cool." |
#3 |
![]() ![]() Join Date: Jun 2013
If you open the FactoryTalk Activation Manager, select the Advanced tag, then the File Access category, you will see a button labeled "View Diagnostics". This will open a viewer that shows specifically (USB dongle, license server, grace period, etc...) how the product was activated in the past.
Until you get things resolved with Rockwell, you could run with the one-week grace period on a different computer from a refresh installation, assuming you can find the installation files. Unfortunately, to obtain replacement installation files from the Rockwell Automation site, you would need to know your customer account logon information as well as the serial number and product key that came with your original RSLogix 5000 purchase. Might as well add those to your list of things to track down. |
#4 | |
![]() ![]() Join Date: Feb 2012
Quote:
The second question ... If all you want are the programs, the .acd files should be in C:\RSLogix 5000\Projects if the software was installed with default settings A search of C drive for *.acd should show you the PLC programs if they are not in the default directory. [or C:\Studio 5000\Projects ] From there you can copy to a network or USB stick and load onto another computer with working licensing to view the programs Last edited by thingstodo; January 9th, 2018 at 06:15 PM. |
#5 |
![]() ![]() Join Date: Nov 2011
In regards to WW software licenses...
Search for *.LIC. It may be archestra.lic or wwsuite.lic. You can open in WW License viewer (or notepad) to see version and if it is development or runtime license.
__________________
****Control Freak**** Net is where I be and Nathan is me. |
Bookmarks |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Factory Talk Activation Tool | WillM | LIVE PLC Questions And Answers | 0 | December 22nd, 2015 08:10 AM |
factory talk activation manager can not start | jugenzhu1963 | LIVE PLC Questions And Answers | 3 | January 29th, 2015 10:58 AM |
Factory Talk Activation | MARC 2014 | LIVE PLC Questions And Answers | 3 | February 14th, 2014 08:20 PM |
Problem with RSLinx Factory Talk Activation | Coulombboy | LIVE PLC Questions And Answers | 2 | September 22nd, 2012 04:29 AM |
Factory talk activation RSLogix500, PanelBuilder | gbradley | LIVE PLC Questions And Answers | 4 | September 18th, 2007 09:27 AM |
