plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 19th, 2017, 01:20 AM   #1
briandubois
United States
briandubois is offline
Proface GP 2401 HMI can't upload from HMI to Laptop
Hi all,
I am trying to upload a proface GP 2401 hmi using com port via the appropriate cable with rs232 to usb adapter. When I start data transfer then select "Receive", the GP PBIII software shows "handshaking..." several times then ends with "GP not responding" and says Receive finished.
Any help would be greatly appreciated and thanks.
Old December 19th, 2017, 01:50 AM   #2
sigmadelta
Canada
sigmadelta is offline
Sometimes USB-Serial converters are hit and miss with certain software packages. I've always had luck with a Digi converter:
https://www.digi.com/products/models/301-1001-11
The 100% guaranteed way is to use a computer with a serial port, or buy the Proface USB cable: GPW-CB03
__________________
Freelance Automation Programmer
Old December 19th, 2017, 02:58 AM   #3
briandubois
United States
Thanks Sigmadelta,
...we have not had this problem in the past with this cable set up and same laptop so I'm feeling like I am missing something.
Old December 19th, 2017, 03:44 AM   #4
sigmadelta
Canada
I'm going by memory now... Try getting to the offline menu on the GP (hold or tap bottom 2 corners simultaneously. Try putting the GP in transfer mode manually.
__________________
Old December 19th, 2017, 03:51 AM   #5
briandubois
United States
Thanks for the reply
Yes, I can go into offline mode, then screen data transfer(took a while because my screens are in Japanese) but still have the same issue.
Old December 19th, 2017, 04:43 AM   #6
sigmadelta
Canada
I have seen these cables fail in the past. Proface had a loop-back test in the offline menu where you attach a loop-back connector to the PC RS-232 side of the cable.
__________________
Old December 19th, 2017, 02:32 PM   #7
briandubois
United States
Thanks, Sigmadelta, I'll look further into the cable. Greatly appreciate the help.
Old December 22nd, 2017, 12:53 AM   #8
briandubois
United States
Bad Cable?
Thanks Sigmadelta.... It was a bad cable after all...
Old December 28th, 2017, 12:35 PM   #9
Izabela
United States
Izabela is offline
What port?
What port are you connecting to on the 2401??
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Softwre required for Proface HMI GP4402-WW Pallab Sur LIVE PLC Questions And Answers 3 November 30th, 2018 08:27 AM
ProFace HMI support cajunconfigurator LIVE PLC Questions And Answers 5 February 15th, 2017 01:04 PM
RSLinx and a New PC based HMI Steve Etter LIVE PLC Questions And Answers 4 September 19th, 2014 09:31 AM
Proface HMI vs Schneider Magelis HMI grnick50 LIVE PLC Questions And Answers 1 September 8th, 2014 05:10 PM
HMI Proface GP 470 mico LIVE PLC Questions And Answers 0 March 29th, 2005 09:21 AM
