plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 21st, 2017, 11:11 AM   #1
alive15
United States
alive15 is offline
Exclamation Fanuc R30iA - How to Run a Background Input Checker Program?
Good morning,
I have a R30iA Fanuc Controller with a main routine running 24/7. Recently, we have added a new machine to the cell, so this machine is outputting a "cycle complete" signal; however, it is not latched in the machine program. I need to look at this input in order for the robot to know when to enter the machine and pick the part.
I need directions on how to latch this input through the robot teach pendant program; So for example, whenever that cycle complete signal comes on, I want the robot to latch this bit internally, and then at the start of the routine, reset that latched bit. I'll use the latch bit to check for cycle complete instead of the actual cycle complete signal coming in.
Thanks,
Old December 21st, 2017, 11:31 AM   #2
alive15
United States
alive15 is offline
Currently looking through three different choices: BG Logic, Flags, and Data Registers. I feel a few of these options may help me with the task at hand, but I'm doing more research on these right now...
Old December 21st, 2017, 06:59 PM   #3
bill4807
United States
bill4807 is offline
Do you have the built in PMC option on the Fanuc robot?
Old December 21st, 2017, 09:34 PM   #4
jstolaruk
United States
jstolaruk is offline
Use background task to capture and set F bits (Flags).
http://www.onerobotics.com/posts/201...kground-logic/
__________________
"You can live to be a hundred if you give up all the things that make you want to live to be a hundred." Woody Allen
Old December 22nd, 2017, 07:49 AM   #5
Sergei Troizky
Canada
Sergei Troizky is offline
I would use a data register, to maintain the latch through reboot, should it happen.
Old December 22nd, 2017, 10:23 AM   #6
alive15
United States
alive15 is offline
@Bill4807 no I do not have it. What does it do?
@jstolaruk That's the plan. Does this work, even when the robot is in teach pendant mode and not auto / robot mode?
@Sergei Troizky Thanks for the reply, I'll stick with the BG logic since I understand it better.
Old December 22nd, 2017, 01:45 PM   #7
bill4807
United States
bill4807 is offline
The PMC fanucs (programmable machine control). It is an option on the robots to utilize ladder logic.
I just wanted to get a better understanding of what type of integration you had that's all.
I guess since you don't have it you need to do it through the robot programs.
Old December 22nd, 2017, 08:28 PM   #8
jstolaruk
United States
Quote:
If I recall correctly, yes. Sorry, it's been ABB and Nachi these last couple of years and I'm in need of getting a Fanuc teach pendant back in my hands to jog some memory cells awake.
__________________
Old December 27th, 2017, 08:54 AM   #9
alive15
United States
alive15 is offline
@jstolaruk Alright thanks, I tested it out myself and it works
@bill4807 Sounds good, thank you.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Fanuc R30iA not working after Expert Tech Support from Fanuc. peelseeds LIVE PLC Questions And Answers 10 September 17th, 2012 06:25 PM
Simulator, Simulation, Shadow Code Terry Woods LIVE PLC Questions And Answers 1 January 2nd, 2005 02:40 PM
GE Fanuc VersaMax Easy Program Store Device CaseyK LIVE PLC Questions And Answers 2 September 13th, 2004 07:38 PM
Program to Run mode Question gizmo LIVE PLC Questions And Answers 3 September 13th, 2004 03:57 PM
Explain the physical input ( switch) interface with PLC program ? Brij LIVE PLC Questions And Answers 5 February 15th, 2003 12:56 AM
