plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 27th, 2017, 01:44 PM   #1
daveco
Supporting Member
United States
daveco is offline
Converting LD to FBD
How would I create the following in Function Block?
I'm using Unity Pro but if you can show me an example in any logic software, I can build it in Unity.
Basically if EFV (Effluent valve) is closed, I want a ZERO value to be transferred. If it's not closed, I want it to show the NTU value but I need to work off of the same Input. In other words I don't have a EFV_Open contact to work with.
I'm having a hard time figuring out how to duplicate the NC contact portion.
Old December 27th, 2017, 01:47 PM   #2
daveco
Supporting Member
United States
daveco is offline
I'm in the process of converting LD984 to either LD or FBD and trying to figure out which will be the best way to convert it. I know the LD works, but just looking at my options.
Old December 27th, 2017, 03:52 PM   #3
daveco
Supporting Member
United States
daveco is offline
I found "A" way to do it, but it seems messy. If anyone has a cleaner/simpler way, I'm all eyes.
Used the XOR block that requires only one of the inputs will produce an output, if both have power (1) than no output.
Old December 27th, 2017, 04:05 PM   #4
daveco
Supporting Member
United States
daveco is offline
In action
Old December 28th, 2017, 12:23 PM   #5
daveco
Supporting Member
United States
daveco is offline
I meant LL984
Old December 28th, 2017, 12:30 PM   #6
Saffa
New Zealand
Saffa is offline
It looks like you're doing a Quantum LL984 conversion...
Unity now has MOVE instructions. No need to use SUB to put values into registers.
You don't need the XOR. Just use the "Valve Closed" bit on the EN pin, right click on the pin and select "Negate pin".
There is also a NOT function block if you want to make it more obvious.
I would personally take your Flow GT 100 and feed the result into an AND block with the valve closed input as the second input. Use the result as an EN for a MOVE block.
Old December 28th, 2017, 01:12 PM   #7
daveco
Supporting Member
United States
daveco is offline
That works! Thanks Saffa! I hadn't thought about the NEGATE option. I changed to the Moves yesterday after finding them.
The results:
Old December 29th, 2017, 03:55 AM   #8
Saffa
New Zealand
Saffa is offline
looking much better. Still one sub in the that can be turned into a MOVE.
We are doing an LL984 conversion to FB for a WWTP at the moment and getting rid of a few hundred SUBs has been almost therapeutic. I used to hate having to think about what each pin would do when i used to troubleshoot the old program
Old December 29th, 2017, 02:28 PM   #9
daveco
Supporting Member
United States
daveco is offline
We're on the uphill side of the water cycle from you :-)
As you're finding out, SUBs are used everywhere in the Modicon water world. I'll put some thought into how to replace that sub but I need a zero value when the contact is closed.
Oh... Simply use the EN pin and move the zero! Duh!
Thanks.
Old December 29th, 2017, 07:33 PM   #10
Lare
Finland
Lare is offline
Unity have different program scan than old modicons.
Unity have scan from left to right then down.
Old modicons from up to down and then to right.
This means that you probably also need to move your zeroing measrument by valve closing under GT block.
Otherwise you still have reading on Unity if input is over 100 but there is also close_valve input on "1" state.
Doh, there is negated input also
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Writing a ST compiler Peter Nachtwey LIVE PLC Questions And Answers 60 September 21st, 2012 04:27 PM
Omron S6 cpu jrojas12345678 LIVE PLC Questions And Answers 12 February 11th, 2011 07:21 AM
s7 200 gaannesh LIVE PLC Questions And Answers 10 April 21st, 2008 12:33 AM
OMRON C28 Instruction recycled_mind LIVE PLC Questions And Answers 7 May 26th, 2007 02:05 AM
Could you help me? Convert STL to Ladder Program with Omron PLC vnn LIVE PLC Questions And Answers 14 January 23rd, 2005 11:06 AM
