plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 28th, 2017, 07:48 AM   #1
CJlikesCHAIRS
Abu Dhabi
CJlikesCHAIRS is offline
GE Profinet Ethernet vs Fiber for remote IO panels?
Is there a difference using ethernet or fiber in GE Proficy 9.0 using profinet? We have an issue where a panel has been moved and ethernet can't be used (about 440 ft ethernet run) and it isn't working properly. Is there anything we have to do in the PLC program to change the connection to use fiber instead of ethernet? The switch in the main panel has 8 ethernet and 4 fiber ports and I think our PNS cards (RX3i) have 2 slots for the SFP cages.
I've never used any fiber before, just looking for some advice/examples on how the fiber works within Proficy or if there are no changes needed.
Old December 28th, 2017, 10:58 AM   #2
Bit_Bucket_07
United States
Bit_Bucket_07 is offline
Bit_Bucket_07's Avatar
Converting wired Ethernet to Ethernet over fiber optics should be invisible to the end devices, although I have encountered some media converters that were incompatible with others. It's possible that you have a defective switch or port, or that your fiber optics are not properly terminated.
Generally speaking, Ethernet is Ethernet, regardless of the transmission media.
__________________
Old December 28th, 2017, 11:01 AM   #3
CJlikesCHAIRS
Abu Dhabi
I guess now it's time to check the fiber terminations. Thanks for the help!
Old December 28th, 2017, 11:07 AM   #4
Bit_Bucket_07
United States
Quote:
If all else fails, you could simply install an Ethernet switch as a repeater somewhere between the two terminating points (assuming that this is a physically viable option) and stay on wired Ethernet.
__________________
Old December 28th, 2017, 01:27 PM   #5
sjohnson
United States
sjohnson is offline
sjohnson's Avatar
Lengths make a difference as standard Ethernet would You could use a repeater or Switch but would not do it in a high speed servo type setting.. Being a HMI probably not an issue but well worth the effort to see the results. Read this off one of the Profinet PDF,s I have on hand.. Not all switches are created equal either.. Had one that worked with a Emerson SM Profinet module but not the SI Profinet.
From PDF
Its 100Meters for Electrical (Cat5/Cat6 cable)
Its 26Km for Optical (Fiber optics network)
Its 100Meters for Radio wave (WLAN)
Old December 28th, 2017, 06:02 PM   #6
henrynp1
United States
henrynp1 is offline
You are using the discovery tool with your computer connected to to the profinet network, correct? You may check the device to make sure you have the correct GSDML file. If you have a newer version installed, you will more than likely not find / or have issues communicating
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Two 1756-L72 -> One 1756-EN2T-> Ethernet IO curlyandshemp LIVE PLC Questions And Answers 4 November 29th, 2017 08:18 PM
Differnce between Profinet and ethernet. kiran LIVE PLC Questions And Answers 5 November 19th, 2009 06:18 PM
Profinet and Ethernet networks tim2 LIVE PLC Questions And Answers 4 November 11th, 2009 01:52 PM
Ethernet connection to GE 9030. BigAl LIVE PLC Questions And Answers 3 October 23rd, 2005 10:35 PM
GE Fanuc Ethernet Remote IO Question jimbo3123 LIVE PLC Questions And Answers 3 January 31st, 2005 03:12 PM
