How words are in an Integer in PLC5/04 Processor?
IdealDan
May 2017
MA
480
Hi Friends!
How many words are in an Integer in PLC5/04 Processor?
In an INTEGER Say N10:0, N10:1, N10:2, N10:3..........N10:x WHAT IS THE ACCEPTABLE MAXIMUM/LIMIT NUMBER or WORD per say? (I mean value for x=?)
Max should be 255. One way to verify would be to create a new offline SLC project in RSLogix500 for the type of processor you have and create a new Integer data file containing, say 1000 elements.
If you need more than 255, I believe there is a setting in the processor status file to allow indexing across data files. (Edit: this method can cause unexpected results & run time faults if used improperly. Be sure to read and understand all SLC programming manuals before attempting)
don't forget element 0
Actually you can have a total of 256 elements per integer file in a SLC or Micrologix. The highest element number will be 255.
Hi I am being given several fault words (as a DINT) from a Drive that I am receiving into a Compactlogix L33ER controller. I have a small...
1,134
So I need to be able to give 10 people passwords to the machine and I need to make a log of when they are used. It's a Rockwell l71 processor and...
880
The topic of reading or writing floating-point values via Modbus seems to come up regularly, and it is to my mind not that difficult. That said...
1,375
I have a customer that has a GT1575-VNBA and I think they are using GT Designer. They have the software and program for both the HMI and the PLC...
2,287
Hello, I am using Machine expert - basic with an M221 PLC. I have two 16 bit modbus registers coming in and I want to convert to a 32bit real...
3,864
