How to emulate RSLogix5000 program with SoftLogix chassis Monitor
IdealDan
May 2017
MA
480
Hi Friends!
What is the PROCEDURE to emulate RSLogix5000 program with SoftLogix chassis Monitor please?
Your input will be well Appreciated
I have a few clarifying questions for you. Are you creating a new RSLogix 5000 project for learning purposes or working with an existing project? What version of RSLogix 5000 or (Studio 5000) are you currently working with? Is there a reason you need to use SoftLogix 5800 instead of RSLogix 5000 Emulate? Do you already have the Rockwell software available, or are you also asking about what software you need to acquire?
Thanks Nomographer for your interest in helping me.
1. Are you creating a new RSLogix 5000 project for learning purposes or working with an existing project? NEW PROJECT FOR LEARNING PURPOSES
2. What version of RSLogix 5000 or (Studio 5000) are you currently working with? V13.04
3. Is there a reason you need to use SoftLogix 5800 instead of RSLogix 5000 Emulate? YES- REASON IS BECAUSE I DO NOT RSLOGIX 5000 EMULATE BUT I HAVE SOFTLOGIX.
4. Do you already have the Rockwell software available, or are you also asking about what software you need to acquire? I ALREADY HAVE ROCKWELL SOFTWARE, I NEED THE PROCEDURE FOR EMULATING WITH SOFTLOGIX
Thanks in advance as I wait your respnse.
Nobody is going to give you a PROCEDURE for this, if you want a procedure read the Softlogix manual, after all you said you were learning.
1 - Install Softlogix
2 - Add virtual CPU
3 - Add virutal ENBT
4 - Download
It's really not much different than setting up physical hardware.
Of course, you'll have to deal with firmware version issues, and when you use a Softlogix the hardware tree will be lost so any hardware tree IO references in the program will generate errors due to the missing IO. You'll have to figure out a method to deal with that so it can compile and run on a SoftLogix.
Note, the Softlogix does not EMULATE anything, it's an actual software-based controller.
You will need to make sure that the major versions of RSLogix 5000 and SoftLogix 5800 are the same. You mentioned 13.04 for your RSLogix.
13 = Major version
.04 = Minor revision
Your SoftLogix software must match the major version (13) but the minor revisions do not need to match.
Version 13 is quite old. It was designed for Windows 2000 and Windows XP. You might run into issues trying to install in a modern operating system.
OG
Hi Guys!
I'm almost done on this, I can add I/O module, configure Processor, RSLinx BUT when I toggle bit from the controller side(I/O Data) in run mode after Downloading, NOTTHING changes. COULD SOMEONE BE KIND TO HELP ME HEERE PLEASE?
I am currently using softlogix 5800 to create virtual chassis. I have added the softlogix 5800 controller, SIM Modules in the I/O Configuration. But I could not find any analog modules to add to the I/O configuration.I am using few analog I/O in the original RSLogix 5000 program. Any idea to mimic the analog modules. Thanks
I haven't personally used SoftLogix 5800, but I believe it only emulates the processor and not the I/O modules. You should use RSLogix 5000 Emulate.
The reason that "notthing changes" is that your "real" PLC is scanning its "real" I/O, and changing whatever value you put in with the "real" value.
If it can't communicate with the I/O modules that it "knows" should be out there (because they're in the I/O tree), then it reports the default, which is zero.
If you go into the configuration of each module, there's a checkbox for "Inhibit module" that should (I haven't worked with SoftLogx, but it does on a physical CLX) prevent the PLC from even trying to scan it's I/O, allowing you to write your own values.
Good luck
Error: Invalid attribute value. Error: Object can not perform service in its current mode/state. Error: Failed to download tags. I get these...
3,822
I have recently made a career change after 25 years of being an electrician. I am officially a junior automation controls programmer. I recently...
362
Hello Experts, I'm wondering if this has been done before if possible to create an Emulate file that have motion control axis? I tried to...
145
I have installed Studio 5000 Professional version V36 a time ago and installed today Logix Emulate V36. I have a exsisting PLC program, but...
707
Hello everybody I would like to know if it is possible to simulate an exchange of messages (MSG) between two MICROLOGIX 1500 in the EMULATE 500...
481
