plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 29th, 2017, 05:09 AM   #1
dezuiper
Belgium
dezuiper is offline
TWINCAT V3 : timers in function block
I have just started programming in TWINCAT to get some experience in structured text. I have just finished my first function block but I have hit a problem. My timers do not count inside a function block. What am I doing wrong?
The block is manipulated via a visualization.
Code:
PROGRAM MAIN
VAR
    myValve : FB_PNUEMATICVALVE;
    setOpen : BOOL;
END_VAR
myValve(bSetOpen:=setOpen);
Code:
FUNCTION_BLOCK FB_PNUEMATICVALVE
VAR_INPUT
    bSetOpen : BOOL := FALSE;
END_VAR
VAR_OUTPUT
    uiWarning : UINT := 0; //b1: valve sensor error
    bIsOpen : BOOL := FALSE;
END_VAR
VAR
    fbTimerValve : TON;
    fbTimerFeedBack : TON;
    usiState : USINT := 0;
    usiLoopAttempts : USINT := 0;
    bSensorOpen : BOOL := FALSE;
    bSensorClosed : BOOL := TRUE;
    bValve : BOOL := FALSE;
    bFeedBack : BOOL := FALSE;
END_VAR
CASE usiState OF
    0: // STATIC
        IF bSetOpen <> bIsOpen THEN
            fbTimerValve(IN:=TRUE, PT:=T#100S);
            //fbTimerFeedBack(IN:=TRUE, PT:=T#50S);
            usiState := 10;
            bValve := bSetOpen;
        END_IF
    10: // MOVING
        IF fbTimerValve.Q THEN
            fbTimerValve(IN:=FALSE);
            IF bSensorOpen OR bSensorClosed THEN
                uiWarning := uiWarning OR E_BIT_MASKS.b1;
            ELSE
                uiWarning := uiWarning OR E_BIT_MASKS.b2;
            END_IF
            usiState := 20;
            RETURN;
        END_IF
        IF fbTimerFeedBack.Q THEN
            fbTimerFeedBack(IN:=FALSE);
            uiWarning := uiWarning OR E_BIT_MASKS.b5;
            usiState := 30;
            RETURN;
        END_IF;
        IF (bSensorClosed AND NOT bSetOpen) OR (bSensorOpen AND bSetOpen) THEN
            usiState := 0;
            bIsOpen := bValve;
        END_IF
        IF bFeedBack = bValve THEN
        END_IF
    20: //ERROR, try looping
    30: //Crititcal ERROR, do nothing
END_CASE
Old December 29th, 2017, 05:34 AM   #2
L D[AR2,P#0.0]
United Kingdom
L D[AR2,P#0.0] is offline
The is no call to fbTimerValve in state 10 to allow the timer to timeout.
Old December 29th, 2017, 05:52 AM   #3
dezuiper
Belgium
dezuiper is offline
Is this the proper way to handle timers?
Code:
fbTimerValve();
fbTimerFeedBack();
CASE usiState OF
    0: // STATIC
            usiState := 10;
            bValve := bSetOpen;
        END_IF
    10: // MOVING
            ELSE
            END_IF
            usiState := 20;
            RETURN;
        END_IF
            usiState := 30;
            RETURN;
        END_IF;
            usiState := 0;
            bIsOpen := bValve;
        END_IF
        END_IF
END_CASE
Old December 29th, 2017, 07:13 AM   #4
kolyur
United States
kolyur is offline
kolyur's Avatar
You have the calls to the timers on the outside of the Case statement, which is correct--they need to run every scan. The preset value can be specified in the call since it never changes. You shouldn't try to re-execute the timer inside the Case; instead just change the IN parameter to enable or disable the timer.
Code:
fbTimerValve(PT:=T#100S);
fbTimerFeedBack(PT:=T#50S);
CASE usiState OF
    0: // STATIC
            fbTimerValve.IN:=TRUE;
            fbTimerFeedBack.IN:=TRUE;
            usiState := 10;
            bValve := bSetOpen;
        END_IF
    10: // MOVING
            fbTimerValve.IN:=FALSE;
            ELSE
            END_IF
            usiState := 20;
            RETURN;
        END_IF
            fbTimerFeedBack.IN:=FALSE;
            usiState := 30;
            RETURN;
        END_IF;
            usiState := 0;
            bIsOpen := bValve;
        END_IF
        END_IF
END_CASE
__________________
John
Old December 30th, 2017, 03:17 PM   #5
paraffin power
England
paraffin power is offline
paraffin power's Avatar
I put TON in CASE statements like this..
Code:
Case Seq OF
    10:
    IF fbMyTimer.Q THEN //advance
        Seq := 20;
    END_IF;
    fbMyTimer(
              IN := <Your Condition> AND (Seq = 10),
              PT := T#2s
    20:
    //next step....
This keeps everything to do with the timer in one place.
Putting the (Seq = 10) clause in tidies up behind itself.
I also use ENUMs for the Sequencer rather than an INT type variable, but that doesn't change the functionality.
Pp
__________________
Whatever hits the fan will not be evenly distributed.
Old January 4th, 2018, 01:16 PM   #6
shooter
Netherlands
shooter is offline
shooter's Avatar
Be sure the timers are running, outside of any case, as they have to be called to see if the time is elapsed.
__________________
shooter@home.nl
skype shooter paul.deelen
Computer Shooter
Paul Deelen
J. Wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
+31653300739
Old January 4th, 2018, 01:17 PM   #7
shooter
Netherlands
shooter is offline
shooter's Avatar
and call them only one time to start.
__________________
shooter@home.nl
Computer Shooter
Paul Deelen
+31653300739
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Function Block Memory Allocation in Omron CJ1M PLC scrambled LIVE PLC Questions And Answers 0 September 1st, 2015 09:50 PM
"Function block call requires a function instance" when calling action in Codesys standeven LIVE PLC Questions And Answers 9 April 27th, 2015 04:11 AM
TWINCAT make function block persistent nachovr LIVE PLC Questions And Answers 4 August 22nd, 2014 05:34 AM
RS5000 function block g7283jl LIVE PLC Questions And Answers 9 October 24th, 2012 10:12 PM
how to assign a data block to function block usman LIVE PLC Questions And Answers 4 April 13th, 2009 09:55 AM
