plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 30th, 2017, 11:33 AM   #1
MRM
Algeria
MRM is offline
S5-95U analog output
I m new in STEP 5 and i need help
I have problem with the onboard's analog output 4-20mA, i want to forced it to see if it work or not but i didn't find the assignement in S5 Program. As i know, normally it's in FB251( XE)
SPA FB 251
XE : MW 12
BG : KF +8
KNKT: KY 0,0
OGR : KF +1000
UGR : KF +0
FEH : M 2.1
BU : M 2.2
i forced MW 12 but no signal!!
Please i need help
Old December 30th, 2017, 11:40 AM   #2
JRW
United States
JRW is offline
JRW's Avatar
Is there a qwxxx or awxxx somewhere?
Maybe you can track that back to this call
Old December 30th, 2017, 11:48 AM   #3
MRM
Algeria
MRM is offline
i checked the assignement list now there is no AW or QW, all are memory assignement or digital I/O
Old December 30th, 2017, 12:01 PM   #4
MRM
Algeria
MRM is offline
MW 12 used only on this
SPA FB 251
XE : MW 12
BG : KF +8
KNKT: KY 0,0
OGR : KF +1000
UGR : KF +0
FEH : M 2.1
BU : M 2.2
A DB 20
L DW 48
T MW 10
A DB 21
L DW 48
T MW 12
A DB 22
L DW 48
T MW 14
BE
one is onboard analog output and the other two are for the external analog module
Old December 30th, 2017, 01:36 PM   #5
moggie
England
moggie is offline
moggie's Avatar
The analog output is normally QW40.
Monitor this value directly and then "force" MW12 (dont forget to block the existing T MW12)
Old December 30th, 2017, 01:45 PM   #6
JRW
United States
JRW is offline
JRW's Avatar
Moggie
For a quick test... could he raise UGR to a 1000?
Old December 30th, 2017, 02:06 PM   #7
moggie
England
moggie is offline
moggie's Avatar
JRW
That is possible and the error bit(s) will come on as well
Without the program not sure if these error bits are used to indicate faults, stop the machine etc.........
Old December 30th, 2017, 03:44 PM   #8
MRM
Algeria
MRM is offline
I tried L KF +500
when I measured the output, I found -74 mA
can you told me what is the problem ? and what i have to do ?
thank you very much in advance for your help
Old January 1st, 2018, 12:38 PM   #9
ivo.maenen
Belgium
ivo.maenen is offline
ivo.maenen's Avatar
Did you connect pin 15 (M) and pin 10 (+QI)?
The manual says it is 0-20 mA.
__________________
Assumptio mater errorum est.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Connected Components Workbench Analog Output Programming grant.dotulong LIVE PLC Questions And Answers 1 December 7th, 2017 02:05 PM
SLC analog output problem rta53 LIVE PLC Questions And Answers 12 January 10th, 2015 03:49 PM
Controllogix analog output OF8H not reaching 20mA bit3399 LIVE PLC Questions And Answers 20 August 12th, 2014 01:22 AM
No output from analog voltage output module rguimond LIVE PLC Questions And Answers 8 July 15th, 2014 06:11 PM
Siemens S7-300 Analog Output Cyanogen281 LIVE PLC Questions And Answers 3 June 26th, 2014 12:31 PM
