plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 31st, 2017, 11:32 AM   #1
ganutenator
United States
ganutenator is offline
ganutenator's Avatar
how to cut cost on a cookie cutter program
M340 1000, ethernet car, 64 in, 64 out, 8 analog in.
Thinking about converting to the wago.
Thoughts, cigarettes?
Old December 31st, 2017, 12:16 PM   #2
PLC
United States
PLC is offline
Do what most pos oem’s do, tell Wago you build 1000’s a year.
Beat them down on price and have them convert your program for free
Old December 31st, 2017, 12:51 PM   #3
osmanmom
Malaysia
osmanmom is offline
Cut with this
Old January 2nd, 2018, 01:48 AM   #4
DwSoFt
Canada
DwSoFt is offline
Is this the carwash program?
Although changing hardware may save money long term it's not cost saving as far as the program itself is concerned.
You can utilize defined function blocks and different languages as needed if possible to make it easier to build the program in the first place.
__________________
Dan Wiebe
Automation Manager
Phoenix Energy Services
Old January 3rd, 2018, 04:14 AM   #5
chud
South Africa
chud is offline
chud's Avatar
Is the ethernet card (NoE or Noc) necesary? Ethernet cpu will save cost but then you will loose some functions. Depends what you use the ethernet card for at the moment
Old January 3rd, 2018, 09:58 AM   #6
RET
United States
RET is offline
Click
__________________
This statement is false.
Old January 3rd, 2018, 11:57 AM   #7
keshik
Canada
keshik is offline
I would recommend taking a look at the Schneider M241 and M251 line of PLCs instead. I previously worked at an integrator that used both Schneider and Wago. The Schneider was a lot less expensive. The Wago tends to include the cost of its bonus features which you may not need (SD card, integrated web page visualizations, etc.).
Both program in Codesys so you're at pretty much a wash there.
Old January 3rd, 2018, 05:00 PM   #8
gclshortt
Canada
gclshortt is offline
gclshortt's Avatar
BRX Series PLC may work for you.
https://www.automationdirect.com/do-more/brx/index
Here is a quick system BOM for the IO you are looking for.
Regards,
File Type: xls BOM-PLC Config Wed Jan 03 2018 16_50_56.xls (23.0 KB, 8 views)
__________________
Garry
https://www.accautomation.ca
Connect with us on Facebook: facebook.com/accautomation/
Old January 3rd, 2018, 07:12 PM   #9
V0N_hydro
Canada
V0N_hydro is offline
that's about a $4k USD PLC.
I had to look at the cost savings of using Automation Direct hardware instead of M340 and I found that we could save 25-40% if we used non isolated IO, which for our applications (power plants) I think is asking for trouble calls since there are so many different voltages, neutral currents, different power systems on the generation and transmission side, and analog sensors run hundreds of metres off the ground grid to measuring sites by the river where they are susceptible to potential differences due to transmission system faults and lightning.
So maybe you could use AD hardware and get down to $2500, but personally I like the unity software and the $1500 savings wouldn't be worth the hassle of 1) re-programming 2) working with crappier software and hardware going forwards.
Citect just doubled in cost so we bailed on that and are putting in the time to recreate the HMIs in Ignition.
Old January 3rd, 2018, 09:19 PM   #10
Cow
United States
Cow is offline
Like Garry posted above, AD comes in at $1446. That's a $2500 savings....
The software used for the BRX system Garry quoted is great to work with, in my opinion.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
CompactLogix program won't download? Zlinger LIVE PLC Questions And Answers 4 March 28th, 2014 07:51 PM
Cost to develop a PLC program Stephen Luft LIVE PLC Questions And Answers 13 January 19th, 2003 01:08 AM
Omron C200h-cp114 rbbalaji LIVE PLC Questions And Answers 7 January 2nd, 2003 04:36 AM
Last Rung rookie1 LIVE PLC Questions And Answers 17 November 18th, 2002 06:57 PM
SLC 5/03 data loss andydaoust LIVE PLC Questions And Answers 1 October 10th, 2002 07:38 PM
