plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 1st, 2018, 01:00 PM   #1
itsm0s
Canada
itsm0s is offline
Problem in Eplan Electric P8
Hello all,
I got an issue with connecting components in Eplan Electric P8. I used this software before for my three line drawings but this is a new issue with new installation.
The problem is when I try to connect a component to a main bus using a T connection (or any other connection type), Eplan doesn't recognize all pins as usual. It only detects the left pin as you can see in the attached images.
I know there must be something wrong with grid setting but I tried different numbers for grid and none of them worked.
I should add that i have no issue with connecting two components together and this happens when Im trying to use connection points. I also aligned all components into the grid but still doesnt work.
Do we have any expert Eplan Electric P8 user here to help me?
Thabk you
Old January 1st, 2018, 01:26 PM   #2
Marshy
United Kingdom
Marshy is offline
You could try pressing I to make the connection points visible, perhaps you have a break point between connections?
Cheers
Rich
Old January 1st, 2018, 01:42 PM   #3
itsm0s
Canada
itsm0s is offline
Quote:
Originally Posted by Marshy View Post
Cheers
Rich
Thanks Rich.
Yes I tried aligned to grid command and didnt work.
Now I pressed the " I "and as I see there is actualy one connection point on the left pin and wire can be connected to that! Why is like that? It is the same for all omponents! But as I said I can connect two different components together with no problem! See the attached image. What do you think?
Old January 1st, 2018, 02:07 PM   #4
Marshy
United Kingdom
Marshy is offline
Unfortunately i don't have eplan with me to try and replicate your problem.
Have you tried adding an additional Motor Circuit Breaker and linking them together? Not sure it will make a difference but you do have the circuit breaker upside down try varient A
Old January 1st, 2018, 02:10 PM   #5
itsm0s
Canada
itsm0s is offline
Smile
Yes. Two motors can be connected together with no problem! That's why I have no idea what must be wrong here.
No worries. Thanks for your reply Rich. I will share the answer if I could find it.
Old January 2nd, 2018, 01:31 AM   #6
the_msp
United Kingdom
the_msp is offline
the_msp's Avatar
Strange. Is the page setup as a schematic: multi-line and not single-line?
Did you individually place the T connections? Try deleting them, holding in mouse left click to the top left of them, drag over to the right and let go.
__________________
Regards,
Patrick
https://www.youtube.com/user/MrMatrixEngineering
Old January 2nd, 2018, 07:25 AM   #7
itsm0s
Canada
itsm0s is offline
Hi Patrick,
It is a schematic multiline page. And yes I placed them individualy.
I believe it's a grid issue because when I change the grid size manualy, even the left pin cannot be connected! If you have Eplan installed on your system, can you please see what is the grid size for you from options--->settings ?
Old January 2nd, 2018, 07:56 AM   #8
the_msp
United Kingdom
the_msp is offline
the_msp's Avatar
I can check, but it will be 3 hours as my laptop with eplan on is at home.
In the meantime, try the multi-place suggestion, it's a neat trick I didn't know about until I went on the training course.
__________________
Regards,
Patrick
Old January 2nd, 2018, 08:09 AM   #9
itsm0s
Canada
itsm0s is offline
Cool. I don't have access to my computer either. So no rush.
I'll try that as well. Thanks for suggestion.
Old January 2nd, 2018, 09:48 AM   #10
boneless
United States
boneless is offline
Just for the heck of it, can you try to place a connection point over the breaker?
Maybe the terminal point of that symbol is pointing up?
Old January 2nd, 2018, 01:19 PM   #11
the_msp
United Kingdom
the_msp is offline
the_msp's Avatar
I couldn't find the grid size in options/settings.... but note my eplan is old now (P8 1.9)... I just have grid size A-E on the top menu.
However, I think boneless may be on to something here. Comparing your symbol to mine, yours looks like a T-node right. You need a T-node down (F7), or press tab key on your nodes to rotate them.
__________________
Regards,
Patrick
Old January 2nd, 2018, 08:42 PM   #12
itsm0s
Canada
itsm0s is offline
Thank you for checking. And yes I'm using T-node down. I tried other types of connections like angle down and O tried different components but still doesn't work!!!
Can you please go to Options menu and then select Settings? Then you can find grid sizes in 2D settings. Just search grid size if you couldnt find it. I attached an image regarding this.
And yes mine also has 5 diffdrent grid sizes but we can adjust them.
Old January 3rd, 2018, 12:25 AM   #13
the_msp
United Kingdom
the_msp is offline
the_msp's Avatar
Found it
__________________
Regards,
Patrick
Old January 3rd, 2018, 11:02 AM   #14
itsm0s
Canada
itsm0s is offline
Found it
Thanks Patrick.
I tried your grid size and still doesn't work. I think better ask to contact their local tech support. This is a really weird problem! I'll share the answer if I found.
Old January 3rd, 2018, 11:41 AM   #15
the_msp
United Kingdom
the_msp is offline
the_msp's Avatar
Try turning snap to grid off and using the multi-place trick... it automatically aligns the placed objects with other objects
__________________
Regards,
Patrick
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Problem in reading electric diagram. gdalianis LIVE PLC Questions And Answers 5 January 12th, 2017 04:43 PM
Eplan electric P8 1.9 big fonts after recover project maruder1991 LIVE PLC Questions And Answers 0 October 25th, 2016 06:45 AM
Roll Grinding CNC Machine Problem BIJOY LIVE PLC Questions And Answers 1 May 23rd, 2010 03:28 PM
Ab Plc5 Rio Problem. fernandes LIVE PLC Questions And Answers 5 March 7th, 2004 01:25 PM
PLC5/40 Backplane Problem????? Andrew Evenson LIVE PLC Questions And Answers 18 August 24th, 2002 07:06 PM
