![]() ![]() ![]() ![]() This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() ![]() Join Date: Jan 2016
Videojet 1620 with siemens plc
Hi guys,
currently working on the communication with videojet 1620 printer (Continuous Inkjet Marking), in there operators manual (http://www.videojet.com/content/dam/...tor-Manual.pdf) the say : Code:
- How to Configure Ethernet Port Refer to WSI/ESI Communications Protocol addendum for more information. But cant find this addendum anywhere in the web, all i did found is this pdf "Videojet 1510 and 1210 Simple Communications Protocol". https://fr.scribd.com/doc/180020947/...t-WSI-Protocol I'have try it with th eprinter using the Ethernet port and all i can find open is the FTP(21), 3000, 3001 and VNC(5900). An d i have send same packets from the WSI/ESI to the print via 3000 and 3001 with Packet Sender but the response was empty!! is there any one that know this protocol ESI/WSI or did work with this printer or simillar ? i found this info in the FTP folder : Code:
<?xml version="1.0" encoding="utf-8"?> <CONTROLLER_INFORMATION> <START_DATE date="07/09/2016"/> <HARDWARE BoardType="CSB4"/> <VERSIONS> <WINDOWS_CE Eboot="4.0.3" CE_Image="2.0.9"/> <SOFTWARE Type="Excel" Version="1.0.423.0" SVN_Build="28116M"/> </VERSIONS> </CONTROLLER_INFORMATION> |
#2 |
![]() ![]() Join Date: Dec 2007
for printer , use port 9100
#3 |
Thank you
#4 |
all
#5 |
#6 |
![]() ![]() Join Date: Nov 2016
yacineamk, Was having the same problem, for the protocol, write to me gmkariz@gmail.com
#7 |
![]() ![]() Join Date: Mar 2015
VideoJet Printers Specifically use port 3100, or 3101 for multihead applications. Just finished an application using Rockwell 5380 Controller. TCP Socket Commands or an EIP to TCP Converter module will be required.
#8 | |
Quote:
#9 |
#10 |
yacineamkamk, I have the addendum that you have been looking for. Its a detailed document that could be of assistance to you. Please advice how I can send it to you since the file is 1.32 MB bytes that exceeds the forum's limit of 300.0 KB.
I was able to develop a desktop application that is able to print using Videojet printer by uploading a text file containing random serial numbers for use in GS1 serialization Track and Trace for a pharmaceutical company and a seed company. The software can use serial and Ethernet ports. Please advice if you know any company that would be interested in buying this software |
Bookmarks |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Siemens or Omron? | Gromit | LIVE PLC Questions And Answers | 35 | November 14th, 2017 10:44 AM |
Siemens PLC won't auto-run after power-up | Lamboom | LIVE PLC Questions And Answers | 5 | August 19th, 2014 04:32 PM |
Plc suggestion | aec | LIVE PLC Questions And Answers | 36 | January 2nd, 2012 01:56 AM |
Beckhoff and Festo PLC comparison to Siemens S7 | kemppioy | LIVE PLC Questions And Answers | 0 | April 26th, 2008 04:12 PM |
Communication on ethernet between AB PLC and Siemens PLC | Chandrashekhar_basap | LIVE PLC Questions And Answers | 4 | May 28th, 2006 03:03 PM |
