Micrologix 1200 Help
Doug4329
Jan 2018
Mississippi
Have a micrologix 1200 module with 1 1762-IA8 input card and 3 1762-OA8 output cards. The first input card seems to be working fine but the 3 output cards show all contacts energized when nothing should be and the main module has a fault saying that there is a mismatch with module 2 which is the first output card. All connections seem to be fine and output cards seems to be externally okay. I tried switching the first output card with a brand new one and the new one is working fine so now it says mismatch with module 3 which is the next output card. But the last 2 output cards are still showing all contacts energized. What can cause this and is there anyway to fix these output cards?
I would say double check and correct the user program I/O configuration so that the object types match the actual configuration you have. If that doesn't work I've had some good success here!
i need HELP, Hello everyone i have a problem like this, i made just two buttons letter A and B in my Hmi proface AGP 3200 , and i make a simple...
1,860
Hi there, new to the site. I have a big problem. My company had a panel built years ago for a machine that we had already been running. They never...
1,436
We have: micrologix 1200 1762-L40BWA with two 1762-IQ16 16pt input modules one 1762-OW16 16pt relay output module My configuration is correct in...
1,913
I do not use AB products much and need some help getting a few things to work using a Micrologix 1200 and a 4" Panelview 800. The software that I...
7,830
Hello, I'm an intern at this power plant and I'm new to PLC programming. I'm hoping to get some help from the professionals in this forum. I...
22
5,945
