plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 3rd, 2018, 01:24 AM   #1
muds
Pakistan
muds is offline
rslogix5000 1 sec pulse
HI ,,
I Want to create 1 sec pulse in rslogix 5000.
can anyone tell how to create this. so that i can calculate machine runtime.
thanks,
Old January 3rd, 2018, 01:48 AM   #2
tarik1978
Morocco
tarik1978 is offline
The bellow thread should help you
http://www.plctalk.net/qanda/showthread.php?t=43936
Old January 3rd, 2018, 07:13 AM   #3
daba
United Kingdom
daba is offline
daba's Avatar
Quote:
Originally Posted by muds View Post
HI ,,
thanks,
How much do you want to count up to ?
Why not use a RTO (Retentive Timer-On) set for 1 hour, and a counter to count hours.
2,147,483,647 hours is 89,478,485 days, or more than 245,146 years !! I think much more than enough for the application....
__________________
___________________________
ControlLogix & SLC Training
a-b train ltd.
abtrain@tiscali.co.uk
www.abtrain.co.uk
tel: 07506 73 9999
nil illegitimi carborundem
Old January 3rd, 2018, 07:42 AM   #4
Aabeck
United States
Aabeck is offline
Aabeck's Avatar
Quote:
I pity that poor maintenance technician on 245,147 years
And probably won't have the right version either.
Old January 3rd, 2018, 08:02 AM   #5
widelto
Colombia
widelto is offline
widelto's Avatar
Its better to use an AOI called "elapsed time add on instruction".
Go and download it from :
http://search.rockwellautomation.com...time%20elapsed
__________________
My two cents.
Old January 3rd, 2018, 08:42 AM   #6
Paully's5.0
United States
Paully's5.0 is offline
I use the system clock for this, built an AOI to handle it but essentially I'm using a GSV to get the WallClockTime parts. I then use a one shot rise/fall on bit.0 of the time part I am interested in to create a second/minute/hour...etc pulse.
That pulse is then used with a counter in various parts of the program where needed.
Note, my AOI is in ST and has output bits for sec/min/hour pulses.
Old January 3rd, 2018, 08:52 AM   #7
John Morris
United States
John Morris is offline
John Morris's Avatar
Not an original design
It's fairly accurate.
__________________
"When nothing is going right, go left."
"Even a fish wouldn't get into trouble if it kept its mouth shut."
(I should probably look into this)
Old January 3rd, 2018, 08:55 AM   #8
widelto
Colombia
widelto is offline
widelto's Avatar
Paully I like your approach, I do not want to reinvent the wheel, can you post it ?
__________________
My two cents.
Old January 3rd, 2018, 10:33 AM   #9
daba
United Kingdom
daba is offline
daba's Avatar
It's only as accurate as it can be, bearing in mind you haven't accounted for the timer accumulator being greater than 1000 which it can be, depending on how frequently it is scanned.
The error will always be positive, so your "Tick" will always be longer than 1 second.
__________________
a-b train ltd.
www.abtrain.co.uk
tel: 07506 73 9999
Old January 3rd, 2018, 11:30 AM   #10
Bit_Bucket_07
United States
Bit_Bucket_07 is offline
Bit_Bucket_07's Avatar
HI ,,
thanks,
You don't need a 1 second pulse bit if you create a program within a 1000 ms periodic task. You can then simply operate your math statements unconditionally and they will be processed once per second.
You should know that you'll eventually run into rounding errors if totalizing with floating point math, unless you take measures to prevent this from happening.
__________________
Old January 3rd, 2018, 11:57 AM   #11
Paully's5.0
United States
Quote:
Here is the ST, the AOI parameter input/output definitions should be pretty obvious.
Code:
// Get PLC Time
GSV(WallClockTime,,localdatetime,DateTime[0]);
// Parse out PLC time to friendly format
year := DateTime[0];
month := DateTime[1];
day := DateTime[2];
hour := DateTime[3];
minute := DateTime[4];
second := DateTime[5];
microsecond := DateTime[6];
// 1 Second pulse generation
// Triggered by the rise/fall of bit 0
SecondOSR.InputBit := second.0;
OSRI(SecondOSR);
SecondOSF.InputBit := second.0;
OSFI(SecondOSF);
secPulse := (SecondOSR.OutputBit OR SecondOSF.OutputBit);
// 1 Minute pulse generation
MinuteOSR.InputBit := minute.0;
OSRI(MinuteOSR);
MinuteOSF.InputBit := minute.0;
OSFI(MinuteOSF);
minPulse := (MinuteOSR.OutputBit OR MinuteOSF.OutputBit);
Old January 3rd, 2018, 01:02 PM   #12
Aardwizz
United Kingdom
Aardwizz is offline
Aardwizz's Avatar
Let me count the ways
The most commonly found in code (also the most inaccurate, but good enough for Motor Run Times
AUX OneSecTmr.DN OneSecTmr
+------TON --+
---| |------------|/|-----------| PRE: 1000 |
Use the OneSecTmr.DN bit as your pulse.
The inaccuracy in this code is on the order of 2% short. You lose one full scan, plus the overrun of the scan time when the TON was last executed.
Since the "Run Time" is mostly for guestimating ("That's a lot of time; we should get ready to service it") or comparison ("Motor A has more run time than Motor B"), accuracy isn't an issue.
The code that John Morris posted is a more, but not perfectly accurate. It eliminates the missed scan (for not-true TON to reset the .DN bit), but still loses scan elapsed time (as daba pointed out)
Presumably you are counting seconds to display hours. If you use a TON to actually time hours, you lose lots of fractional hours each time the motor turns off. A Retentive timer prevents that loss, and putting the reset before the timer means that the DN bit will be on for one scan.
OneHrPulse.DN OneHrPulse
----------| |-------------[ RES ]
AUX OneHrPulse
+----------RTO--+
--------| |------------| PRE: 3600000 |
The amount of inaccuracy in this timer is on the order of .001%. More than good enough for Run Time, and if you want to include fractional hours, just add your integer hour count + ACC/PRE.
The most accurate 1 sec pulse counter is to
AUX RUNNING_TMR
+-------------RTO--+
--------| |------------| PRE: 2147483647 |
+-----------GRT---+ +------------SUB---+ OneSecPulse
----| RUNNING_TMR.ACC |--------| RUNNING_TMR.ACC |---------( )-
| 1000 | | 1000 |
+-----------------+ | RUNNING_TMR.ACC |
The timer never DONEs out, and is never reset. But it also never accumulates more than 1 second of total elapsed time. It never loses the scan overruns.
Overkill for a Running Time counter, but is as accurate or more as using a Timed Task.
Old January 3rd, 2018, 01:43 PM   #13
A_G
United States
A_G is offline
I used this method (retentive timer) with a customer that wanted run time for different pumps to estimate when to perform maintenance on them.
Old January 3rd, 2018, 02:47 PM   #14
John Morris
United States
You are correct kind sir, but the application didn't call for T*Ts on timing. It just needed to count out ten minute cycle times, +/- 2 or three seconds was ok.
I wouldn't have used it for high speed bottling/canning.
I figured it would have suited the OP's request.
__________________
Old January 3rd, 2018, 03:07 PM   #15
rankhornjp
United States
rankhornjp is offline
There is a P_RunTime AOI that will track runtimes and number of starts, its part of the PlantPAX library.
http://literature.rockwellautomation...m010_-en-e.pdf
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1 sec pulse bit running up my ADD instruction to fast Snap25 LIVE PLC Questions And Answers 12 April 20th, 2015 11:39 AM
Foxboro CFT50 pulse output 95ee32069 LIVE PLC Questions And Answers 0 January 6th, 2011 01:24 PM
5 Sec Clock Pulse bit timmer shresp LIVE PLC Questions And Answers 1 November 6th, 2007 08:29 AM
Pulse Count - not exactly what flowmeter says it should be (Logix 500) TimD LIVE PLC Questions And Answers 9 October 2nd, 2007 09:55 PM
s7-200 High Speed Pulse Output / Counter hawkeyen2001 LIVE PLC Questions And Answers 0 September 19th, 2007 07:28 AM
