Power Adapter for S7-1200 DC
segment
Oct 2016
Netherlands
Hi Guys,
I am just trying some PLC stuff to learn by myself.
I am buying a Siemens S7-1200, DC DC DC (1212C with power input as DC) model. I guess I need a separate power adapter for it but I did not find any reference for which power adapter I should purchase, is there any specific model?. My CPU model is 6ES7 212-1AE40-0XB0.
Thanks!
From a quick glance at the wiring and specs, you need a 24vdc supply that can supply ~900ma w/ all the possible modules.
So i'd get a 50W or better 24vdc supply and no worries.
Thanks, so can something like 6EP1332-1SH71 from Siemens (Power Module PM1207) works with the 1AE40-0XB0?
Cheers
Pretty much any 24V supply with enough current will work, but that one certainly does the trick.
I can recommend the one you picked (depending on what else you need to power).
Alternatively, you could pick up an AC/DC/* model which can be supplied with 110/230V directly.
Not any 24vdc power supply will work. Trust me I have had my trouble with an older model and replaced it with a newer supply. If you bye a brand new power supply there shouldn't be a problem:)
What issues have you run into? Just curious :)
Hello All, Im pretty confident i fried my ac adapter. It is a 120vac to 24 vdc power relay, sdr-120-24. I had it hooked up to a...
17
4,031
Hey everyone! Looking for some help on a power supply I'm trying to "mod". I have a old HP AC power adapter for 100-240VAC input @ 1A with a...
19
6,058
We have a few profibus networks that have ABB ACH 550 drives using the RPBA-01 profibus adapter for control. The issue we currently have is that...
3,943
First time I've used either the software or this unit. This is the setup I have right now. I have 20mA coming into AnalogIP1. Both the Main.PV...
36
Hello..I am new to Plc.I have Mitsubishi Melsec Fx3Ga-40MR PLC controlling a machine for packing powder.Currently the Plc has issue which power...
128
