plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 17th, 2018, 06:58 AM   #1
AClarke678
United Kingdom
AClarke678 is offline
Can't receive any data through modbus client
Hi everyone,
I am trying to read a Modbus register in an Intelipro Unit with a S7-1200 over Modbus TCP using MB_Client. But i'm not able to receive any data through modbus client function. I am getting 16#7006 status on my modbus block stating that info is being received but the done bit is never getting activated.
I have been on with both Siemens and Comap and both companies claim I have everything set up correctly either end.
I have attached screenshots of my setup. if anyone can spot something. Any help would be greatly appreciated.
Old January 17th, 2018, 08:11 AM   #2
BryanG
United Kingdom
BryanG is offline
Remote port should be 502 and Local Port can be left as zero, unless you are doing something tricky with port mapping on a router.
If that doesn't fix it you need to be doing some diagnostics on the LAN to see if data is coming out of the PLC. Disconnect the Intelipro and set you laptop to use its IP address, then run Hyperterminal or similar connected to Port 502 so that you see the data coming out of the PLC.
Old January 17th, 2018, 11:35 AM   #3
tragically1969
United Kingdom
tragically1969 is offline
Quote:
Originally Posted by AClarke678 View Post
Hi everyone,
Personally I would prove using ModPoll or similar from a PC that the Intellipro was indeed serving data serving data before i got anywhere near a PLC
Old January 18th, 2018, 04:32 AM   #4
AClarke678
United Kingdom
I have connected the Intelipro with ModScan and can read all values within the holding registers within the Intelipro.
The port is the Intelipro is port 23 which is why i have it set to that and I have also set local port to 0 and still no data.
When I disconnect the Intelipro from the PLC (unplug the cable) the status sits at 16#7002 (Immediate Call) and moves up to 16#7006 (Information being received) when I plug the Intelipro back in, so it is seeing a connection but just doesn't display values of the registers.
I have also connected my PLC with a modbus simulator within my PC and it doesn't display any of the values I have forced through the simulator.
Old January 18th, 2018, 08:27 AM   #5
BryanG
United Kingdom
BryanG is offline
Which version of MB_CLIENT are you using. I had problems with V4.0, V4.1 seemed to fix things.
Does make it look like a PLC problem, though I would be happier if you used a terminal program rather than a Modbus simulator to be certain that no data is coming out of the PLC. It just removes a layer of complication. Or if the Modbus simulator has something that just tells you what data is coming in on that port. You did reset the port on the PLC to 502 or set the simulator to use 23?
Looking at your Modbus DB Setup file I can see that you have a StatusCap variable that I am assuming is a captured Status, this is showing 16#8380 and that error is "Received Modbus frame has incorrect format or too few bytes were received."
Old January 18th, 2018, 10:21 AM   #6
BryanG
United Kingdom
BryanG is offline
Also you need to think about a firewall blocking port 23, it is the normal telnet port and is very likely to be blocked on your PC.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Wago eCockpit CoDeSys - Modbus TCP Client Issue Hal9000 LIVE PLC Questions And Answers 4 November 13th, 2017 05:13 PM
client is asking about Red Lion Data Station Plus with Scadapacks defcon.klaxon LIVE PLC Questions And Answers 9 August 9th, 2017 08:15 PM
Opinion: Prosoft Modbus card or Red Lion Data Station Plus? Bullzi LIVE PLC Questions And Answers 5 August 3rd, 2016 08:44 PM
How do I pull Modbus Data over Ethernet: CompactLogix Thinkster LIVE PLC Questions And Answers 9 June 24th, 2014 10:35 PM
Modbus on RS-485: a frame without data Ken Roach LIVE PLC Questions And Answers 18 December 18th, 2009 04:30 PM
