plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 17th, 2018, 09:34 AM   #1
ACURALEGENDZ
United States
ACURALEGENDZ is offline
B&R 4PP420-1043-75 (or any power panel really) How to add calibration at startup?
I'd like to know how to add touchscreen calibration at startup. Ive seen this done on customers machines but have been unable to figure out how to implement in my own programs.
I'm using AS 3.0.90.18
Old January 18th, 2018, 08:38 PM   #2
seth350
United States
seth350 is offline
seth350's Avatar
Never have messed with the calibrations but could you take a look at the templates that have the calibration button built in and reverse engineer from there?
Seems if it should only occur on first ever start up, that you would need a flag setup in the plc to retain that the screen has been calibrated. There is probably a flag built into the power panel just for that already.
Then I would think you would need to display the calibration screen if the flag is false, some how or another.
Sorry to be not so much help, but there are few here with experience with B&R. I am relatively new to them myself.
Old January 25th, 2018, 12:45 AM   #3
CapinWinky
United States
CapinWinky is offline
CapinWinky's Avatar
As you probably know, buttons and hotspots have different key types (set, momentary, toggle, change page, etc). Well, one of them is CalibrateTouch or something like that. Almost every B&R HMI I've done for the past 12 years has had a splash screen with a big hotspot on it somewhere that starts calibration that way.
The slightly better way to handle this is by using a spare digital input to trigger one through the VisAPI library. That keeps malicious operators from jacking up the calibration on purpose to force some down time.
The little button on the settings page of all the demos is useless. If the calibration actually goes off, it would be a pain to navigate to and press that button.
__________________
Cycling power is a sign of weakness.
Old January 25th, 2018, 07:28 AM   #4
seth350
United States
seth350 is offline
seth350's Avatar
Quote:
Good point, I didnít think of that.
Old January 31st, 2018, 11:10 AM   #5
ACURALEGENDZ
United States
Any idea how to create that splash screen? That's exactly what I'm looking to do. I know how to add touch calibration button, and I'm sure I could figure out how to do the same with a hot spot but the splash screen is something I'm unfamiliar with. Thank you
Old February 2nd, 2018, 08:01 AM   #6
CapinWinky
United States
CapinWinky's Avatar
In the Visual Components editor, if you click on the main heading in the tree (it will have the name of your HMI), then look in the properties window on the right, you can tell it which page to start on (default page) and you can also map program variables to a CurrentPage and ChangePage so you can tell in the program what page you're on and change the page.
I usually make a little HMI program that has a timer and use the output of that timer to run a little progress bar on the screen. When the timer is done, I check if you're on the splash screen still and if you are, I change the page to the main screen. Instead of waiting on the timer, you can go early if your drives have come online (DriveStatus.NetworkInitOk) and your SafePLC is online (the RemoteControl function from the AsSafety library can tell if it's in Run-Safe).
Either way, give yourself a small hot spot in the corner to exit the splash screen, then a huge hotspot over the rest to do calibration. Make sure to click the "bring to front" button with the hotspots selected so they are on top of your logo, progress bar, company service department contact info, etc.
__________________
Old March 13th, 2018, 12:02 PM   #7
ACURALEGENDZ
United States
Thank you that worked great
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
B&R power panel boot loading problem Iman LIVE PLC Questions And Answers 5 October 30th, 2015 01:56 AM
Parallel 24V DC power supply for control panel? Possible? flyers LIVE PLC Questions And Answers 26 November 15th, 2011 04:44 PM
Power drops to control panel question... James Fillmore LIVE PLC Questions And Answers 6 January 16th, 2011 09:20 AM
B&R Power Panel 4PP220.1505-B5 Chandrashekar LIVE PLC Questions And Answers 0 September 14th, 2008 08:24 AM
Plc Rack And Power Problems plcnovel LIVE PLC Questions And Answers 7 May 30th, 2006 04:51 PM
