plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 19th, 2018, 08:02 AM   #1
poj101
Ireland
poj101 is offline
TIA Portal & Cognex FB
Hi All,
I am looking for a FB for Siemens TIA v14 to read/write to a Cognex Insight (7000 & 2000) over Profinet.
I have written multiple Rockwell programs using Cognex cameras but this is my first venture into Siemens...
I'm slowly getting my head around it
Cognex provide some great support for RSLogix / Studio 5000 but there doesn't seem to be much available on the Siemens side. I have set up the network side of it and thought I'de ask the question before I start writing code. Has anyone come across FB's similar to the Rockwell AOI's that are available?
Old January 19th, 2018, 08:34 AM   #2
JRW
United States
JRW is offline
JRW's Avatar
Should be easy. You have a gsd file from Cognex?
Old January 19th, 2018, 09:53 AM   #3
JRW
United States
JRW is offline
JRW's Avatar
Have you seen this?
https://www.cognex.com/support/downl...&langtype=1033
Old January 19th, 2018, 12:51 PM   #4
dwoodlock
United States
dwoodlock is offline
dwoodlock's Avatar
I'm not sure how much you will find about 3rd party devices on the Siemens technical message board, but you could definitely give it a browse.
https://support.industry.siemens.com...h/?text=cognex
Additionally you can enter a service request for technical questions related to Siemens hardware/software. They tend to respond very quickly, and it doesn't cost anything.
good luck
Old January 19th, 2018, 02:45 PM   #5
janner_10
Supporting Member
United Kingdom
janner_10 is offline
You shouldn't need a FB, just add the GSD, the Cognex manual will tell what data to read. I did a project a couple of years ago with a 5 series camera, I can post some screenshots.
Old January 19th, 2018, 04:12 PM   #6
JBA-DK
Denmark
JBA-DK is offline
Be aware of what kind of switch you place between plc and camera. A couple off weeks ago I had trouble getting a datalogic barcode reader working on profinet. I can't but maybe some other can explain why some switches will work and others will not. I was online on both plc and camera at the same time but the plc kept failing missing hardware. Connecting the plc directly to the camera and fault was gone. I replaced the switch and the problem was solved. Both switches were unmanged simple switches but different brands.
Old February 6th, 2018, 02:42 AM   #7
poj101
Ireland
poj101 is offline
Hi Guys,
Thanks for the pointers. Cognex support responded with a manual and some sample code. Pretty straightforward. Too large to post unfortunately. DM if anyone needs it
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
run Step 7 without TIA Portal dmned64 LIVE PLC Questions And Answers 4 June 7th, 2017 06:39 AM
TIA Portal V13 FB for WAGO 750-637 Encoder Scarra LIVE PLC Questions And Answers 5 October 31st, 2016 09:34 AM
TIA Portal V13 Emergency Stop FB schui LIVE PLC Questions And Answers 8 December 29th, 2015 03:31 PM
Change FB number on Know How protected Function blocks - TIA Portal rQx LIVE PLC Questions And Answers 3 September 28th, 2014 09:06 AM
Siemens OP77B Trouble in TIA Portal Tim James LIVE PLC Questions And Answers 4 December 24th, 2012 03:27 PM
