Delta HMI alarm logging
Adilishtiaq
Jan 2018
Karachi
Hello everyone,
I am using delta DVP-B10E615 HMI with delta 28SV plc.
I have 30 alarms to display on HMI, means for 30th alarm i will have to move 536870912 as a numeric valve to Specific data register lets say D10, (mov K536870912 D10) and K1073741823 for all 30 alarms, which is a huge valve.
Is there any other solution in ladder for 30 different alarms.
Actually i am confused how to add all numeric values for 30 alarms. (1+2+4+8+16+32+64+128..so on) for all 30 alarms occurred on same time. Because acumulative value is a huge number (1073741823).
Thanks and regards
Adil
I am facing a Problem while configuring Delta HMI Alarms. There is only one Address where I can specify only one word and there are list of...
3,509
Hi, We have a customer that has an old DOP-A80THTD1 that is needed to be upgraded Can we upload from these units? Is there a special...
87
Hello, I know little English, I want to use 4 plc cqm1 as slave (modbus), and hmi delta as master. Unfortunately, I cannot establish rs485...
569
I'm trying to establish communication between an HMI DELTA (DOP-B07E515) and a PLC IDEC (FC6A-D16R1CEE) via the RS-232C/485 module (FC6A-SIF-52)...
554
Hello, I'm facing a problem in communication between my delta TP70P-32TP1R HMI and DVP20EX2 PLC. I tried multiple ways in order to set the...
1,306
