plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 22nd, 2018, 04:07 PM   #1
ganutenator
United States
ganutenator is offline
ganutenator's Avatar
text file into excel
I wrote a script in Indusoft that backs up recipes to a text file.
I would like to allow the customer to view these in excel.
Old January 22nd, 2018, 04:34 PM   #2
dmroeder
United States
dmroeder is offline
dmroeder's Avatar
Uhh, right on...
I guess since you didn't really give many specifics, nor did you ask an actual question, I'll just say copy and paste the data in your text file into excel.
Old January 22nd, 2018, 04:46 PM   #3
spaderkung
Sweden
spaderkung is offline
Just open it in XL.
Format it before save into columns w any delimiter, XL will ask upon open.
__________________
Jon Bolmstedt, Inspired Automatician.
Old January 22nd, 2018, 04:51 PM   #4
Bit_Bucket_07
United States
Bit_Bucket_07 is offline
Bit_Bucket_07's Avatar
https://en.wikipedia.org/wiki/Comma-separated_values
__________________
Old January 23rd, 2018, 04:05 AM   #5
cardosocea
United Kingdom
cardosocea is offline
You don't even need to use csv as long as the formatting is done consistently.
In Excel, go to Data tab, In the Get External Data section, you can choose from text, point to the file and define how the file is formatted for it to be able to split the data into cells.
Old January 23rd, 2018, 06:05 AM   #6
AustralIan
United Kingdom
AustralIan is offline
You can no longer purchase hyundai excels new. Consider using an i30 for your application.
Old January 23rd, 2018, 02:58 PM   #7
NetNathan
United States
NetNathan is offline
Is it a CSV file?
InduSoft supports Active-X. The "Microsoft Spreadsheet" Active-X supplied with OWC11 will work to show CSV.
http://www.indusoft.com/Marketing/Ar...ntrols-Webinar
Are you using InduSoft Web Studio? It has recipe functions:
http://www.indusoft.com/Marketing/Ar...oft-Web-Studio
__________________
****Control Freak****
Net is where I be and Nathan is me.
Old January 23rd, 2018, 03:37 PM   #8
exabmorgan
United States
exabmorgan is offline
I've done this exact procedure with Indusoft Web Studio. The issue is that in a recipe data file Indusoft stores arrays of tags that are strings with a space between them and arrays of numbers with linefeeds. If the recipe doesn't have arrays than every line is a separate tag.
So the attached macro for excel in a text file works on four arrays, the first two are strings, the second two are numbers.
The recipe is loading arrays that contain 300 tags.
File Type: txt Calcs.rcp.txt (266 Bytes, 9 views)
Old January 23rd, 2018, 07:51 PM   #9
exabmorgan
United States
Crud, I screwed that post up, code is good but that 'makes' a recipe from an Excel worksheet. And you said you wanted to Read a recipe.
Hopefully this excel file clears it it up, it does both write and read. (100 elements in these arrays)
Old January 24th, 2018, 09:38 AM   #10
ganutenator
United States
the indusoft saves data values to a text file. here a snipet of what the text file looks like:
I would like to allow the customer to view this as in a format that makes more sense to them.
Thinking of maybe using the vb in excel to read the lines of the text file and put them in the proper cells? but I don't know how to do that at the moment.
[Speed Config]
Pre1WashPassSpd=1.35
Pre1SlowFrntSpd=0.80
Pre1SlowRearSpd=0.80
Pre2WashPassSpd=1.35
Pre2SlowFrntSpd=0.80
Pre2SlowRearSpd=0.80
HiPressWashPassSpd=1.25
HiPressSlowWashPassSpd=0.70
HiPressSlowFrntSpd=0.70
HiPressSlowRearSpd=0.70
TriFoamWashPassSpd=1.50
LpChem3PassSpd=1.25
FoamWaterfallPassSpd=1.30
PresoakDwellPassSpd=1.50
RepositionPassSpd_hmi=1.57
MedPressPassSpd=1.57
SpotFreeWashPassSpd=1.25
TopMedPressPmpSpd=30
SideMedPressPmpSpd=30
SideHighPressNormalPmpSpd=48
SideHighPressTallPmpSpd=60
UnderbodyPmpSpd=30
Old January 24th, 2018, 09:55 AM   #11
Steve Bailey
United States
Steve Bailey is offline
Steve Bailey's Avatar
Does Indusoft gives you the option of saving as a .csv file or are you limited to .txt?
A .csv file is also a text file that Excel can open.
If Indusoft won't let you save as .csv, I suggest you create an Excel spreadsheet that displays the data the way you want and then save it as a .csv file. Open the .csv file with Notepad to see how the tagnames and values are arranged. Then modify your Indusoft script to create a file that matches the way the data is presented in the .csv file.
Old January 24th, 2018, 10:00 AM   #12
ganutenator
United States
I want excel to read the file, look for ex: "Pre1WashPassSpd" and put it's value in a cell that I made pretty for the customer to see. aka, not display the tag name but something like Easy cleaning: Presoak 1 Wash Pass Speed 1.35 ft/sec. automatically.
Old January 24th, 2018, 10:17 AM   #13
Steve Bailey
United States
In Excel:
Open the text file
Locate the substring "Pre1WashPassSpd="
Extract the characters from the end of that substring until the next CRLF
Convert that to a number and put it into the appropriate cell
Repeat for the next tagname
Old January 24th, 2018, 10:34 AM   #14
gclshortt
Canada
gclshortt is offline
gclshortt's Avatar
Using VBA:
https://stackoverflow.com/questions/...by-line-in-vba
Indusoft has some interesting applications on their website.
http://www.indusoft.com/products-dow...e-applications
An application for DDE to Excel. This would communicate directly to the excel file.
Regards,
Garry
__________________
Garry
https://www.accautomation.ca
Connect with us on Facebook: facebook.com/accautomation/
Old January 24th, 2018, 09:37 PM   #15
ganutenator
United States
Now I am thinking that it would be better to generate a web page w/ the data.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Is it possible to convert a csv in excel to possibly a xls file? jsalzm1 LIVE PLC Questions And Answers 17 June 22nd, 2015 10:33 AM
factory talk : converting MER file to APA aminto89 LIVE PLC Questions And Answers 6 September 19th, 2014 05:25 AM
Siemens Read Text File JasonWade LIVE PLC Questions And Answers 3 January 15th, 2014 05:35 AM
Siemens S7-400, Exporting the online DB values to Excel or text file mailken LIVE PLC Questions And Answers 1 January 11th, 2011 04:54 PM
Intouch 9.5 reporting to Text File curlyandshemp LIVE PLC Questions And Answers 3 June 5th, 2009 06:52 AM
