GX Developer PLC - PC Communication Problem
SAMCRO67
Nov 2017
Glasgow
Hello all,
When trying to establish a serial connection between GX Developer and a Mitsubishi PLC I am faced with the following error message: 'An unusable COM port was specified. Execute again after checking the COM port setting.'
I have checked the cable connection, everything seems fine. I have tried changing to another COM port but I get the same error message every time.
Can anyone help me ASAP? It would be very appreciated.
Cheers.
Right click on Windows "Start" button and select "Device Manager" there you will see the COM ports that your PC recognize.
I have done that. The COM Port stated under Ports is 'COM Port 1' this is the port I have tried on GX Developer and I get the error message. :(
I am trying to use a Medoc SC-03-S1. It was wokring fine in December, I came back today to work on the project and I am now getting this error message.
I followed the video but it still doesn't work. I get the same error message. I have closed down every programme so that only GX Developer is running. I have tried restarting the machine but nothing is working.
Is there any chance RSLinx (Rockwell software) is running on it?
When I use the shop laptop to talk to anything other than Rockwell PLC stuff I have to shut down RSLinx (because it monopolizes the serial port).
MadPoet.
Hi One of the PLC's that I maintain/update is a Mitsubishi Q-Series, probably installed about 10 years ago. At the moment, ALL the wires from...
1,170
Has anyone put together a combination of the Beijer iX Developer software and a Rexroth L54 controller over ethernet? Can't seem to get the...
549
I want to make a backup of the PLC software on to the C-drive of the PC. Just watched a video on this....Does anyone know why you download...
4,082
Hi all, I tried to connect to a FX-48MR PLC for more than an hour last night with no success. Can someone tell me where the "FX" option is in...
2,620
Good Evening, I am an under graduate engineering student presently working on a project involving the Mitsubishi FX3G PLC. I plan to programme...
8,477
