plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 24th, 2018, 02:11 AM   #1
Theboss
South Africa
Theboss is offline
Boiler steam pressure
Good day Gents,
Does atmospheric pressure have an influence of a boiler steam pressure.
Old January 24th, 2018, 07:41 AM   #2
John Morris
United States
John Morris is offline
John Morris's Avatar
Try this, fairly basic
http://www.narrowgauge.iform.com.au/steam4.html
__________________
"When nothing is going right, go left."
"Even a fish wouldn't get into trouble if it kept its mouth shut."
(I should probably look into this)
Old January 24th, 2018, 12:13 PM   #3
dwoodlock
United States
dwoodlock is offline
dwoodlock's Avatar
It would depend on exactly how your boiler is configured. Higher atmospheric pressure = higher boiling temperature and vice versa.
Old January 24th, 2018, 12:18 PM   #4
Theboss
South Africa
Theboss is offline
And if the boiler is a closed system, using the steam to create vacuum and steam tracing. Should we be measuring gauge pressure or absolute pressure of the steam?
Old January 24th, 2018, 12:31 PM   #5
dwoodlock
United States
dwoodlock's Avatar
I am no boiler expert at all. Hopefully someone who has more experience can chime in.
I suspect a absolute gauge would yield a wider range of information for you to consider.
Old January 24th, 2018, 02:31 PM   #6
blaster452
Canada
blaster452 is offline
Boiler pressure is not affected by atmospheric pressure - it is a closed loop. The pressure is usually stated in gauge pressure.
That being said most steam tables are in absolute pressure. If any calculations are to be made convert the boiler operating pressure to absolute first.
Many good online steam tables.
http://www.spiraxsarco.com/Resources...am-tables.aspx
Old January 24th, 2018, 02:55 PM   #7
Theboss
South Africa
Theboss is offline
Why should the boiler pressure (gauge) be converted to absolute pressure for calculations?
Old January 24th, 2018, 03:19 PM   #8
JimboK
United States
JimboK is offline
What is your operating pressure?
Most times the slight difference in atmospheric pressure isn't going to make much difference.
Old January 24th, 2018, 03:21 PM   #9
Theboss
South Africa
Theboss is offline
17bar out of the boiler but downstream we getting 14bar line pressure which is gauge pressure.
Old January 24th, 2018, 03:43 PM   #10
blaster452
Canada
you do not have to calculate in absolute pressure. Just every printed steam table I have used works in absolute.
What are you trying to figure out?
The online steam tables work for gauge or absolute.
Old January 24th, 2018, 03:55 PM   #11
Theboss
South Africa
Theboss is offline
Yeah I noticed that as well.
I'm trying to understand why does absolute pressure hv to be measured for pressure compensation on a flowmeter.
The boiler is a closed system and atmospheric pressure has no influence on the steam pressure from the boiler.
Old January 24th, 2018, 04:03 PM   #12
blaster452
Canada
I believe you just need to convert the gauge pressure to absolute for the flowmeter.
The flowmeter my be able to work at below atmospheric. Maybe the built-in calculations want to work in absolute.
Old January 24th, 2018, 04:08 PM   #13
Theboss
South Africa
Theboss is offline
I believe so too.
Is there any reason why absolute pressure is the preferred method?
Maybe I'm thinking about it incorrectly but since the boiler is a closed loop, gauge pressure(line pressure) should be measured instead. Please correct me if I'm wrong.
Old January 24th, 2018, 04:19 PM   #14
blaster452
Canada
Not sure why it wants absolute.
Maybe the built in calculations are based on absolute. You should be able to just add 14.7 psi or 101.3 kPa to your gauge reading. Or I guess 1.013 bar.
Old January 24th, 2018, 04:26 PM   #15
Theboss
South Africa
Theboss is offline
That's exactly what I did.
But if absolute is what is needed, surely it's for an open loop system (eg. Kettle) where the steam is open to atmosphere
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
pressure transmitter on each pressure vessel Charbel LIVE PLC Questions And Answers 4 January 29th, 2014 04:45 PM
Looking for a strategy to decelerate a hydraulic cylinder Tubularfab LIVE PLC Questions And Answers 56 February 8th, 2012 05:22 PM
Hydraulic fixed deplacement pump and VFD. MrQ LIVE PLC Questions And Answers 13 August 30th, 2006 04:31 PM
Analog Output follow up BoxerBrats LIVE PLC Questions And Answers 33 March 22nd, 2005 12:00 AM
Pressure-Position Orn Jonsson LIVE PLC Questions And Answers 5 July 9th, 2002 04:44 PM
