plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 25th, 2018, 03:36 AM   #1
Combo
Belgium
Combo is offline
DB with alarms, wich alarm was first
I have a DB with many alarms... let's say 500 bits bundled in words.
You all know the problem when hitting an emergency stop that several alarms can be shown. You cannot see wich one was first.
So I was thinking how to solve this one...
I can write a loop that searches in the words or so, but what will I know... I can log the first fault maybe... what to do with the next...
Maybe show only the first within a timeframe of 10s, donno.
I will know wich bit in the DB, but I will not know what text to show, maybe a change with the discrete alarms...
Or I should change the way alarms are show on panels now, link them to a copy of the alarm DB en lookup the first alarm en link that one to the DB that linked to the discrete alarms...
Anyone had this situation before ?
Thanks,
Kind regards,
Gerry
Old January 25th, 2018, 11:53 AM   #2
Lare
Finland
Lare is offline
search alarm bell programs
http://www.plctalk.net/qanda/showthread.php?t=102972
There is link to pdf, which shows example for allen bradley. I don't know of which book it is scanned to internet.
You can try to code it to Siemens
Old January 25th, 2018, 03:36 PM   #3
spaderkung
Sweden
spaderkung is offline
I would initially try and clean it up at the source. For instance after the em stop is pressed, which of your alarms should be disabled?
__________________
Jon Bolmstedt, Inspired Automatician.
Old January 26th, 2018, 08:24 AM   #4
Jeebs
Belgium
Jeebs is offline
Alarm priority through the scan. Highest prio scanned first. Each alarm has nr corresponding to nr on HMI. First active alarm moves its nr into the 'Stop Cause' variable.
It's one way to do it that works the same on the different systems/brands we have.
Old January 29th, 2018, 03:24 AM   #5
Combo
Belgium
Combo is offline
Thanks guys for the replies.
The DB contains many words containing bitalarms. What I can do is using indirect acces to check all bits in a DB into words. In STL this can be done with the adress register. Is there an easy method is SCL also for such ?
Not a TIA CPU, so PEEK and POKE doesn't work.
Thanks in advance,
Kind regards,
Gerry
Old January 29th, 2018, 04:16 AM   #6
Combo
Belgium
Combo is offline
Code
Here is a screenshot of the DB:
It's allowed in STL too... but even then it's not an easy task. Ik can write a loop that checks all adresses, but the goal is this:
When an alarm triggers, a certain bit becomes high in the DB. The thing is, after several PLC cycles other bit's can trigger too, these bits have to be ignored in the first 10 seconds after a NEW alarm. After 10 seconds I must be able to find new alarms as well in the DB.
Main goal: Finding the first alarm and log it.
Kind regards,
Gerry
Old January 29th, 2018, 06:24 AM   #7
BryanG
United Kingdom
BryanG is offline
Only used TIA so this is one of those probably silly answers.
Have copies of the Alarm DB, on the first alarm copy the alarm DB to the first copy, that stores you first alarm. You could go further and add a counter and store the next alarms in more copies.
Old January 29th, 2018, 06:37 AM   #8
Combo
Belgium
Combo is offline
Array
I'm thinking to copy the DB with bits to a DB with an array of bits and then search in that array with SCL code...
Old January 29th, 2018, 07:05 AM   #9
cwal61
United States
cwal61 is offline
Why couldn't you monitor all alarm words = 0. If true then no alarm. If not true then alarm active. If alarm active then run alarm time.
Then condition to set alarm bit would be: All alarms words = 0 OR Alarm Active Timer Done.
Old January 29th, 2018, 07:13 AM   #10
Combo
Belgium
Combo is offline
Sfc20
799 byte's I have,
That's why I'm trying to push things in a loop search.
799 byte's = 6392 alarms.
Even with words, I need something with a loop, I cannot evaluate each word, that would be too much code.
Ik copied P#DB1000.DBX0.0 BYTE 799 into P#DB1001.DBX BYTE 799 with SFC20.
DB1001 is an array of 799 Bits.
Now I can write in SCL a Repeat Until loop to search for an arraybit that is high.
Kind regards,
Gerry
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
AdvancedHMI project example timryder LIVE PLC Questions And Answers 23 August 22nd, 2017 10:17 AM
Alarm Prevention on Powerup Ken Roach LIVE PLC Questions And Answers 5 June 8th, 2013 08:27 PM
Siemens S7-1200 with KTP600 alarms problem Joe Hardane LIVE PLC Questions And Answers 1 January 23rd, 2013 07:26 AM
Alarm Handing cjd1965 LIVE PLC Questions And Answers 17 March 11th, 2012 06:23 AM
Alarm Code mwatkins LIVE PLC Questions And Answers 25 January 15th, 2003 04:43 PM
