plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 26th, 2018, 11:27 AM   #1
Nearbyatom
United States
Nearbyatom is offline
DPDT switch as data switch?
I have a RS485 modbus network. I'm looking at an HMI and a modem as a masters, and I have a proprietary board as a slave.
Obviously we can't have 2 masters on the same network. So I was thinking of using a DPDT switch to switch between masters. RS485 is 2 wires, so have NO wired to 1 master, and the NC wired to the 2nd?
Thoughts?
Old January 26th, 2018, 12:04 PM   #2
gclshortt
Canada
gclshortt is offline
gclshortt's Avatar
Theoretically this it is possible. The system is not usually designed for two masters unless using Modbus TCP (Ethernet). You will have to stop the master that is not communicating to the slave. This may be hard to do.
Can the HMI or Modem be a slave as well?
Can your proprietary board have another Modbus communication port? (Set up another network)
Regards,
__________________
Garry
https://www.accautomation.ca
Connect with us on Facebook: facebook.com/accautomation/
Old January 26th, 2018, 12:53 PM   #3
g.mccormick
United States
g.mccormick is offline
I've done this before, it worked intermittently until the relay got a little oxidation. I went to a port switcher:
https://www.blackbox.com/en-us/store...ontact/SW1047A
Old January 26th, 2018, 01:25 PM   #4
James Mcquade
United States
James Mcquade is offline
it will work intermittently, if at all.
the switch contacts will bounce (chatter) as they close and will create issues.
james
Old January 26th, 2018, 03:10 PM   #5
Nearbyatom
United States
Regards,
I don't think the HMI or modem can be a slave. By definition they are polling for information. The proprietary board doesn't have another com port
Old January 26th, 2018, 03:12 PM   #6
Nearbyatom
United States
james
If the relay was SSR, I shouldn't get bounce/chatter would I?
Old January 26th, 2018, 03:33 PM   #7
Mickey
United States
Mickey is offline
Mickey's Avatar
Quote:
You could try it, but leakage may be an issue with solid state.
Let us know if you do.
__________________
Mickey
If you want happiness for an hour-take a nap. If you want happiness for a day-go fishing. If you want happiness for a month-getmarried. If you want happiness for a year-inherit a fortune. If you want happiness for a lifetime-help someone else.
----- Chinese Proverb
Old January 26th, 2018, 08:43 PM   #8
DwSoFt
Canada
DwSoFt is offline
In this situation I typically use an arbitrator (google scadalink ip100 for example) or an intermediate device (such as a scadapack) that polls the device and then the hosts poll it.
__________________
Dan Wiebe
Automation Manager
Phoenix Energy Services
Old January 28th, 2018, 06:24 PM   #9
rguimond
Canada
rguimond is offline
I've had success using DTDT relays to do exactly what you're wanting to do. I had only several devices that could only be on RS-232. Depending on how fast you need the data, it should work just fine
__________________
"If you can't measure it, you can't manage it!"
Old January 28th, 2018, 09:54 PM   #10
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
Use bifurcated gold plated contacts and it will probably work well. If you switch the relay mid-message you might get an error, but most devices will handle that fine and resume normal functioning.
__________________
It's not all the variables I am most concerned with, it's the undiscovered constants.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Hirschmann Switch + 22COMM-E = No Communication Steve Etter LIVE PLC Questions And Answers 22 July 20th, 2012 01:19 AM
PLC5 Rack As RIO For ControlLogix tgoulding LIVE PLC Questions And Answers 38 May 17th, 2011 04:55 PM
PLC that uses labview as language umlphysics LIVE PLC Questions And Answers 5 September 15th, 2009 01:14 PM
Confused "again" S7 indirect Thim LIVE PLC Questions And Answers 17 July 22nd, 2008 05:47 PM
Copy UDT data to tempory data Werner LIVE PLC Questions And Answers 20 November 16th, 2006 09:42 AM
