Programming a spare Beckhoff CP6207 panel PC 5.7"
Transistor
Aug 2007
Somewhere
25
We have a production unit and a spare unprogrammed panel.
Q1: Does anyone know if we can transfer the program from the running unit to the backup?
Q2: How?
Many thanks.
One precondition that has to be met before trying anything is that the source code was downloaded to the PLC (using specific command in TwinCAT) together with the compiled code.
1. Connect (establish route) to the Panel PC using programming PC (laptop, etc.).
2. In case of TwinCAT 2, you have to download the .tsm (TwinCAT System Manager -> File -> Open from target) and .pro (TwinCAT PLC Control -> File -> Open from PLC) files from the PLC. In case of TwinCAT 3 you just use option "Open Project From Target".
3. Connect to the spare Panel PC and download the files you acquired from running unit.
4. Online > Create Bootproject
5. Online > Sourcecode download
Dear all, I have fx2n plc on my hand but I don't have the programming cable sc-09 and it would not be easy for me to get one. I need the cable...
96
Hi all, i am the new controls guy at the plant and i have inherited a pc from the previous controls guy with Siemens tia portal version 16 and 17...
20
873
I need to pull the program off of an old 90-30 so I can convert it to Allen Bradley. This is my first time messing with GE and I don't have the...
84
New to vfds. I put in parameters. IP, but I get ethernet flashing and link solid. What did I do wrong?
469
I'm been deciphering a program for a press here. I've gotten most of it deciphered using the manual to understand the instructions (first mitsu...
282
