plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 29th, 2018, 03:55 AM   #1
cardosocea
United Kingdom
cardosocea is offline
Little HMI for Control Logix
Hello Gents,
I'm looking for a cheap solution to have a little HMI display connected to a Control Logix PLC through Ethernet.
The HMI is for a remote offloading station and there is little to display or control as the hardwired controls are already in place. The display would be mostly to indicate if the offload pumps were inhibited or not and which alarms that affected the pumps were active.
A simple text display would be enough for this really.
My problem is that Rockwell discontinued their mini displays or will during this year (this is for an external application) and the HMI's available that are tiny seem to be "locked" into Compactlogix or the Micro800 series.
Any advice on brands that would do such a device?
Old January 29th, 2018, 06:32 AM   #2
rdrast
United States
rdrast is offline
rdrast's Avatar
I've switched to using the C-More's from Automation Direct for most of my smaller things. Very easy to duplicate, and enhance, an older PanelView or PV+, and inexpensive.
__________________
How to ask questions the SMART Way!
Look First, Ask Second!
Old January 29th, 2018, 07:42 AM   #3
the_msp
United Kingdom
the_msp is online now
the_msp's Avatar
No personal experience with Red Lion but they are highly regarded/recommended on this forum...
Not sure about mainland RL distirbutor's (edit: https://uk.rs-online.com/web/c/autom...erm=red%20lion ), know there's one here in Belfast (Ashdale Engineering)...
the only "UK" distributor for AD is:
United Kingdom, Ireland
Company:
Address:
LaMonde Automation Ltd.
The Officers' Mess
Coldstream Road
Caterham
Surrey
CR3 5QX
United Kingdom
__________________
Regards,
Patrick
https://www.youtube.com/user/MrMatrixEngineering
Old January 29th, 2018, 07:47 AM   #4
bkottaras
United States
bkottaras is offline
Look into Weintek.
Free software and the price is right.
Old January 29th, 2018, 07:56 AM   #5
Aabeck
United States
Aabeck is offline
Aabeck's Avatar
For portable monitoring of a plating line with a Contrologix I put AdvancedHMI on a Windows tablet, then added a WiFi router to the panel. It's touchscreen and was less than $100.
I use it for calibrating the outputs and readouts of 36 electroplating power supplies.
__________________
Never underestimate the quality of idiots that will be running your machines
http://aabeck.com
Old January 29th, 2018, 08:27 AM   #6
Kidblue
England
Kidblue is offline
Kidblue's Avatar
+1 for a Weintek option. The 4.3" (with Ethernet) is only 180 list and the 7" goes at around 200 (the 10" is under 500 too!). Built in email server for alarms, Remote access (once activated) which allows pass-through, so you could then go online with the CLX PLC. Free software as mentioned that actually has a lot of time saving features that other vendors just don't include yet!
Regards,
Rob
__________________
Rob Howdle
.........For the Boys in Royal Blue !!
Old January 29th, 2018, 08:54 AM   #7
cardosocea
United Kingdom
Quote:
I hadn't thought about that possibility... I would have to add the Wireless access point and so on, but could potentially be quite cheap.
Quote:
Originally Posted by Kidblue View Post
Regards,
Rob
The weintek modules seem good enough, but I can't find a distributor in the UK from their website. Do you know where these can be purchased from?
Old January 29th, 2018, 09:36 AM   #8
Kidblue
England
Kidblue is offline
Kidblue's Avatar
We use Lamonde Automation...
Rob
__________________
Rob Howdle
Old January 29th, 2018, 10:07 AM   #9
lfe
France
lfe is offline
Quote:
there exist also micro usb to RJ45 ethernet network adapters, then theorically it can work without Wireless, and it can get the power through Power over Ethernet ... but I also have to say that I've never tried it
Old January 29th, 2018, 10:10 AM   #10
gclshortt
Canada
gclshortt is offline
gclshortt's Avatar
+1 for the C-More Panels from Automation Direct.
They also have C-More Micro Panels as well.
https://www.automationdirect.com/adc...e_Micro_Panels
Regards,
__________________
Garry
https://www.accautomation.ca
Connect with us on Facebook: facebook.com/accautomation/
Old January 30th, 2018, 09:43 PM   #11
yasirkhi
Canada
yasirkhi is offline
Maple Systems 5097DXL dual ethernet.
Little complex programming but features are awesome.
If you are planning simply ON/OFF feature, go for Automationdirect
If you are planning serious programming graph, trend, email, script macros, dual ethernet, remote montioring from home, cellphones, computers.
Maple Systems 5097DXL (I have programmed 5 of them)
Old January 30th, 2018, 10:36 PM   #12
Ken Roach
United States
Ken Roach is offline
Ken Roach's Avatar
I wouldn't even pause before ordering a C1000 terminal from Red Lion. It's their current line of low-feature terminals.
Crimson 3 software is free, and once you get the basic hang of it very easy to use and powerful.
If Routeco happens to be your Rockwell Automation distributor, they also sell Red Lion.
I used a bunch of the older G304 Kadets on a small product line and have switched to the C1000 after the older ones were discontinued.
Old January 31st, 2018, 03:24 AM   #13
cardosocea
United Kingdom
Thanks.
Some of these options are pretty good to put up a budget solution to display a couple of alarms and interlock conditions on three pumps.
Old February 2nd, 2018, 01:26 AM   #14
Allen123
China
Allen123 is offline
Allen123's Avatar
3mm bezel aluminum Industrial touch monitor
Adopt industrial control HD LCD screen +LED backlight screen,highlight picture,perfect color. Compatible with various industrial systems/application. Support without touch,resistive touch,capacitive touch,IR touch. Whole system is equipped with WI-FI module,more convennient.
Old February 2nd, 2018, 08:41 AM   #15
lfe
France
lfe is offline
If this Control Logix supports Modbus TCP a Android Tablet + an app like this : https://play.google.com/store/apps/d...panel.suppanel a really cheap solution
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Connecting control logix and HMI 700 to PC macstorm LIVE PLC Questions And Answers 3 February 14th, 2016 10:51 AM
Siemens HMI software & comms method ASF LIVE PLC Questions And Answers 18 September 10th, 2015 01:13 AM
RedLion HMI, an AB Drive, and a couple of pumps. David.Reed.Schmidt LIVE PLC Questions And Answers 3 January 18th, 2014 12:34 PM
FactoryTalk HMI architecture computers and panelview mix V0N_hydro LIVE PLC Questions And Answers 2 January 7th, 2014 11:45 AM
Need a low cost HMI that will work with Compact Logix pallen3 LIVE PLC Questions And Answers 5 June 19th, 2009 01:32 PM
