plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 29th, 2018, 10:22 AM   #1
QMS_MAN
United Kingdom
QMS_MAN is offline
QMS_MAN's Avatar
Automation Direct Productivity 1000/ 2000 PLC
I am looking at using this range instead of AB compact logix.
I have had a look at the software manuals and cannot find anything that indicates if this range supports some form of AOI / UDT similar to Logix 5000.
Has anybody used these controllers utilizing said functionality.
Thanks in advance.
__________________
Shaun.
WHAT DO YOU MEAN 4 WEEKS, SURELY ITS JUST COPY PASTE.
Old January 29th, 2018, 10:41 AM   #2
gclshortt
Canada
gclshortt is offline
gclshortt's Avatar
I am just starting to use the Productivity 1000 Series PLC.
The units do not have UDT similar to the Logix 5000. Here is a thread with the same question. The Do-More series has this feature.
https://forum.automationdirect.com/f...3000-structure
AOI (Add On Instruction) - In the productivity suite software, groups of rungs can be placed in a task. This task can be password protected.
Here are the general features of the software.
https://www.automationdirect.com/pro...tware/features
Hope this helps you out.
Regards,
__________________
Garry
https://www.accautomation.ca
Connect with us on Facebook: facebook.com/accautomation/
Old January 29th, 2018, 10:54 AM   #3
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
Thanks in advance.
Nope, but they claim it is in the works.
They're really pretty good little machines and the software is not bad for the price (free). They're have tons of memory and are really fast too. But... I am not convinced that they are as rugged as the other offerings. I have a few of them out in the field and have only had a couple of issues, mostly minor. I did have one failure of a serial port that was probably due to lightning. It is connected to RS485 and about 600' of cable buried in the ground so I added a signal isolator.
I am not sure I will put any more out there, but when the customer is on a budget and it is useful to put the free software on their machine for remote access purposes you can save a ton of money.
Things I love about them:
-Lots of comms ports, lots of power, easy to set up and communicate with. Modbus read and write instructions are superior to A/B stuff. You can talk to about anything with the PxK series.
-Analog modules with built in readouts that can show milliamps for all the channels.
-price...unbeatable bargain.
-bright OLED display right on the processor
-instruction set is somewhat simple but quite powerful. Debounce coils are particularly useful along with rising and falling edge "contact" instructions.
-firmware. the CPUs come ready to run out of the box, and firmware upgrades are easy to perform. The software will even reload the program into the CPU after you update firmware and all of it goes very quickly compared to A/B
Things I don't love:
-Bit numbers start at 1. I don't know why they did this but I actually hate this. Bits always always always start with 0. There is no good excuse for this horrible ugly flaw in my opinion.
-Window arrangement. It ain't RSLogix...You can only edit address descriptions from the tag database and it is in your way when it is opened. The help file is similar.
-Too many tag options. It ain't like A/B where everything is retentive and you can look at tag values online or offline. You get to choose which tags are retentive. You also have initial values, force values, initial force tickboxes...I still don't know for sure what all these extra features are good for, and not sure I understand what will happen if the battery is dead and I cycle power and I have written several complete programs. I had some tag value weirdness happen once, so I replaced some tags with constants to solve the problem.
I don't think they are as capable as Compactlogix. They only do ladder logic and don't support some of the more advanced abstractions or programming techniques, but depending on your situation, they might be more than capable for you.
__________________
It's not all the variables I am most concerned with, it's the undiscovered constants.
Old January 29th, 2018, 02:39 PM   #4
jaden
United States
jaden is offline
You will find Automation Direct tech support to be excellent!
Old January 29th, 2018, 10:56 PM   #5
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
Quote:
That is a good point I forgot to include. They are quick to fix bugs and even quite responsive to suggestions.
__________________
Old January 30th, 2018, 11:38 AM   #6
Bullzi
United States
Bullzi is offline
I have done 1 project with the P2000 and a GS drive. I was a little worried about the ruggedness of the PLC because it is a little "Cheaper" feeling in its construction than a CompactLogix. I am happy to report that I have no failures at all and the project is over a year old.
I will share some of Okie's dislikes. The bit number thing didn't bother me too much but the tag choices are very confusing!! It caused me a lot of problems especially with HMI entered values. I will add 1 dislike to the list: If you use Ethernet and connect a GS drive or anything else that uses the remote IO protocol you have to connect the Ethernet cable to the back port only. So if you may need more than 1 network switch depending on how you have the network set up. 1 for the remote IO and 1 for the HMI or programming port. That seems unnecessary to me but it is the way it is now.
Overall not a bad PLC. A CompactLogix Killer? Maybe not but if you like tag based programming and a modular design this is a good PLC.
__________________
There is never enough money to do it right but there is always enough money to do it again.
Old January 30th, 2018, 12:09 PM   #7
Elcan
United States
Elcan is offline
Quote:
If they add UDTs and Add-Ons, I will replace many CompactLogix in my projects. Probably not all them because, you know, some customers think that nothing other than Allen Bradley (or Siemens) is good enough for their applications.
Old January 30th, 2018, 06:28 PM   #8
kwade
United States
kwade is offline
Quote:
LOCAL variables would be nice, too.
Old January 31st, 2018, 01:51 AM   #9
janner_10
Supporting Member
United Kingdom
janner_10 is offline
I've heard nothing but good on this forum about them but like Hens teeth in the UK, I've seen maybe 2 in 15 years.
Be prepared for some 'What the f**k is that?' questions.
I'd be checking tech support and spares, lead times. It maybe not as good here as in the US.
Old January 31st, 2018, 08:41 AM   #10
icky812
United States
icky812 is offline
icky812's Avatar
AutomationDirect has a very good reseller in the UK, Lamonde Automation Ltd. in Surrey.
Old February 1st, 2018, 03:01 PM   #11
AlThePal
United Kingdom
AlThePal is offline
Quote:
Lamonde add 50% to the US prices. I don't know how they justify that kind of markup.
Old November 1st, 2018, 12:12 PM   #12
Kip Williams
United States
Kip Williams is offline
Currently using P2000s
I've used the P2000s on 3 machines, each controlling servos over Modbus. The units were commissioned at the end of 2016 and so far zero failures & zero downtime. I would not hesitate to use these anywhere I would normally use a CompactLogix.
Old November 1st, 2018, 03:31 PM   #13
sparkie
United States
sparkie is online now
I'm with you. I don't think they are all that rugged of machines. I just used a P2000 for a project. AD tech support is great, though. I also agree with you about them starting their numbers at one as opposed to zero. I'm sure that also added a nice bit of programming.
To answer your question: When the battery dies and the CPU is power cycled, the retentive memory is lost, but the program will stay in the CPU, though I'm not sure for how long.
I love the arrow key method of ladder insertion, though the column system can be a bit clunky and give issue if adding a much longer rung to the program.
I can't wait for some form of UDT in their software, it would make things much more efficient.
Old November 2nd, 2018, 06:38 AM   #14
Cody
United States
Cody is offline
Another alternative that has many ports like the P2000, has virtually unlimited memory, more of an Allen-Bradley style programming, loadable and user functions, more capability than CompactLogix and priced like the P2000 is the Smart SoftPLC.
The programming software is included with your first purchase, support and quality are great - we've used them for many years.
What's more, SoftPLC supports all the A-B protocols (incl the old RIO/DH+) as well as Modbus, ModbusTCP so it is easy to interface to just about any devices.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
A bit of Advice on which PLC, Automation Direct? Edmhydraulics LIVE PLC Questions And Answers 30 September 12th, 2016 12:21 PM
automation direct plc project I AM STUMPED! gr8benwa LIVE PLC Questions And Answers 32 March 13th, 2012 12:41 AM
Automation Direct D4-450 CPU to Emerson SP2402 Servo Drive cmpeters111 LIVE PLC Questions And Answers 0 November 23rd, 2011 02:24 PM
Automation Direct Modbus TCP JACMAN LIVE PLC Questions And Answers 6 April 17th, 2009 11:36 AM
Automation Direct DL-06 jseavers LIVE PLC Questions And Answers 5 February 28th, 2009 09:00 AM
