plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 31st, 2018, 02:03 PM   #1
Bullzi
United States
Bullzi is offline
Red Lion to GE 90-30
Hi Everyone,
Got a new project coming up and one of the older pieces of equipment has a GE 90-30 311 PLC. I would like to connect that to the Red Lion G09 HMI.
I have been doing some research and it looks like the 15 pin connection is RS-485 Communication. Is that correct? If so then connecting it to the G09 485 port should be pretty straight forward. I know RL makes a cable for the communications so I am trying to get a quote for that now.
Next question: I have done some work with GE Versamax and the RX3i processors but never worked with the 90-30. Will my PME 9.5 work to upload the program from the processor? This unit is about 20 years old as far as I can tell. Just wondering if I will have to convert it from some older file source. Let me know your thoughts on that.
Thanks for any advice you can give.
__________________
There is never enough money to do it right but there is always enough money to do it again.
Old January 31st, 2018, 04:10 PM   #2
Steve Bailey
United States
Steve Bailey is online now
Steve Bailey's Avatar
I think you'll have better luck if can convert the Logicmaster or VersaPro project file to PME first.
I just tried an experiment. I cleared the PLC memory using Logicmaster version 9.05. Then I created a new project with the hardware configuration and one rung of ladder logic, a NO contact addressed to %I001 driving a coil instruction addressed to %Q0033. The hardware configuration has a CPU363, two 16-point input modules and two 16-point output modules. I downloaded the logic and hardware configuration to the PLC with Logicmaster, got Logic Equal and PLC running.
I then went online with PME version 7.0. I was able to upload the hardware configuration and the memory values but not the ladder logic. When I tried to upload the ladder logic I got Error 8095 and Error 8509. The help files for those errors were unhelpful in either resolving or understanding the errors.
After uploading the hardware configuration PME still said configuration not equal although the list of modules matched what was present. After downloading the hardware configuration with PME the message reverted to configuration equal.
Old January 31st, 2018, 05:17 PM   #3
Bullzi
United States
Bullzi is offline
I am waiting for the original program but once I get it how do I convert it? Is there a convert utility in PME? I dont have Logicmaster or VersaPro.
__________________
Old January 31st, 2018, 05:31 PM   #4
Steve Bailey
United States
Yes, you start a new project in PME and then you can import both logic and hardware configuration from a Logicmaster or VersaPro project.
Old January 31st, 2018, 08:31 PM   #5
Bullzi
United States
Bullzi is offline
Thanks Steve!!
Am I correct in thinking the DB15 Connection on the CPU is RS-485?
__________________
Old January 31st, 2018, 09:12 PM   #6
Steve Bailey
United States
Also correct. The name of the serial protocol is either SNP or SNPX. The latter is a stripped-down version optimized for HMI communications. The full SNP protocol supports program transfers which of course isn't needed for HMIs. If your CPU311 is really old, it won't support SNPX. Support for SNPX began at firmware version 4.40 in 1994. That corresponds to CPU311L.
Pin assignment for the RS485 port can be found in the manual GFK-0356.
Old February 1st, 2018, 01:43 PM   #7
Bullzi
United States
Bullzi is offline
I just got a picture of the panel. The PN of the PLC is IC693CPU311W. So will that unit have SNPX ?
__________________
Old February 1st, 2018, 01:53 PM   #8
Steve Bailey
United States
Yes, CPU311W is newer than CPU311L.
Old February 1st, 2018, 04:49 PM   #9
Bullzi
United States
Bullzi is offline
I figured but wanted to make sure. Thanks for all the help.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
GE Fanuc Series 90 30 Johnny T LIVE PLC Questions And Answers 31 April 22nd, 2018 04:06 PM
Simulating Unity and Red Lion Crimson 3.0 jordan45 LIVE PLC Questions And Answers 1 January 8th, 2018 01:36 PM
Quickpanel JR migration to Red Lion Kadet Question Plutonius LIVE PLC Questions And Answers 4 May 15th, 2017 12:33 PM
Finally a Red Lion G3 but with Siemens MarkNightingale LIVE PLC Questions And Answers 2 June 29th, 2012 04:33 PM
Red Lion programming issues and answers Rik LIVE PLC Questions And Answers 4 November 4th, 2009 11:14 AM
