plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 1st, 2018, 03:27 PM   #1
aand74
Belgium
aand74 is offline
Safety : two hand operation
I have an application where I should do two hand monitoring for safety.
However, I have several standard inputs, and only one failsafe digital input.
For an operation the button on the failsafe input must be pushed together with one of the buttons on the standard digital inputs.
I should think I need to activate two digital inputs for real safety standard.
Has in my case : combination safety input and digital input, any safety relevance?
Old February 1st, 2018, 04:05 PM   #2
the_msp
United Kingdom
the_msp is offline
the_msp's Avatar
Do it right and use a two hand control relay. I did one recently, ironically in Belgium, can share part numbers etc.
__________________
Regards,
Patrick
https://www.youtube.com/user/MrMatrixEngineering
Old February 1st, 2018, 04:30 PM   #3
jaden
United States
jaden is offline
Bear in mind that a standard PLC is not safety rated. Outputs can short On.
Old February 1st, 2018, 05:11 PM   #4
keithkyll
United States
keithkyll is offline
As mentioned previously, use a safety relay built for that exact function. See these from Automation Direct.
Old February 2nd, 2018, 03:10 AM   #5
cardosocea
United Kingdom
cardosocea is offline
Wouldn't connecting both buttons in series into that digital input do what you need?
I'm not familiar to the standard on this, but seeing as every or nearly every emergency stop button on Earth is wired in series with a couple more, perhaps the same logic can be applied here?
Old February 2nd, 2018, 04:07 AM   #6
Ronnie Sullivan
United Kingdom
Ronnie Sullivan is offline
It's against the regulations cardosocea.
The two buttons have to be pressed within a short time to each other (stops somebody wedging one of them on)
Old February 2nd, 2018, 04:08 AM   #7
nightline
Netherlands
nightline is offline
This is absolute not the way!!! An operator can easily stick one button with tape ore something, and use the other button in "one-hand" mode.
A safety relay mentioned for this function checks for the timing between both rising flanks of both inputs.
Funny thing is that there are also pneumatic types...
Old February 2nd, 2018, 04:36 AM   #8
the_msp
United Kingdom
the_msp is offline
the_msp's Avatar
This is not e-stop this is THC which requires the operator to have both hands placed on a separate button for the entire duration of the dangerous movement. The buttons must be spaced a certain distance apart, the height of this station must be a certain height from the floor to prevent button pressing from the hip etc, the buttons must be shielded. The station must be a certain distance from the danger zone. The THC relay has logic that both buttons must be pressed within 0.5s of each other - releasing either button during the operation requires that both buttons must be released and then set again within 0.5s - this prevents an object being placed on one.
http://www2.schneider-electric.com/r...201A55_05).pdf
__________________
Regards,
Patrick
Old February 2nd, 2018, 05:12 AM   #9
lfe
France
lfe is offline
The right reference : https://www.iso.org/obp/ui/#iso:std:...851:ed-1:v1:en
About 15 years ago I passed a safety inspection by a risk control company and the use of two normal PLC inputs for the two-hand pushbuttons was accepted, but provided they were pressed within 0.5 sec ... but a lot of time has passed and maybe the norm has changed.
Old February 2nd, 2018, 05:49 AM   #10
Ronnie Sullivan
United Kingdom
And here's ya belt and braces circuit diagram
Old February 2nd, 2018, 06:51 AM   #11
cardosocea
United Kingdom
Quote:
Hadn't thought of that. Thanks.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Safety Lock Status in Safety Program Kalagaraz LIVE PLC Questions And Answers 0 May 11th, 2017 10:15 AM
Contrologix "I/O Not Responding" oxlacey LIVE PLC Questions And Answers 15 April 11th, 2016 09:58 AM
Trying to understand safety PLC's (specifically Siemens) Jieve LIVE PLC Questions And Answers 3 June 24th, 2014 09:27 AM
Estop relay question g.mccormick LIVE PLC Questions And Answers 6 December 6th, 2013 07:54 AM
Review of Banner SC22-3 safety controller kolyur LIVE PLC Questions And Answers 1 June 15th, 2008 08:42 PM
