Micrologix 1000 First Scan Bit
VSeaver
Feb 2015
Hamilton
20
I am pretty sure this has been asked before, but I am unable to find it any where. I have a first scan bit I am using to home 2 steppers on power up. The bit never comes on when I go from program to run. I looked in "Processor Status" and under the "Main" tab it says "No" for S:1/15. I am unable to select "Yes" for this. It is greyed out. I am sure there is something I am missing here.
Thanks.
You will never see that bit when monitoring. To prove that it is working use it to drive a counter and then switch modes a handful of times and see if your counter changes.
I have a timer in the same rung as this bit, but it never starts timing. I put a dummy bit in parallel with the status bit and toggle it and the timer times.
Rather than using a timer or counter. Just put a latching rung around S:1/15.
S:1/15 M1
M1 |
When I toggle off the dummy bit the timer does reset. The program is written. So when I do toggle the dummy bit, the steppers home and the program runs fine. It's just when I either cycle power or go from program to run, the first scan bit does not start the first part of my program which is to make sure everything is home before starting the reset of the program. I may be wrong here but I would assume it is something to do with enabling it in the processor status menu.
Normally use something as shown attached. Useful for masking certain alarms or other equipment on power-up. Set the .PRE as necessary.
Regards,
Rob
I am not in front of the PLC right now so I tried the Emulator and put in program and back to run and it worked this time. Not sure what is going on. I will have to try it with the actual PLC when I get to it. It is at another facility at this time. I have attached the program.
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
124
Hi all, We have a very old pit pump system running on Micrologix 1000. Now, whenever there is an alarm for high conductivity, we want that alarm...
1,254
Looking at a Micrologix 1000 1761-L32AWA, I tried to connect using the 1761-CBL-PM02 through a Serial to USB converter (This setup was used...
982
Hello All I am trying to convert a ML1000 program for use in a ML1400. I didn't create the original program & documentation is non existent...
4,403
Hey Folks, I have a customer with an older machine that is controlled with a MicroLogix 1000. The machine just quit working. The power light is...
22
10,548
