plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 4th, 2018, 08:35 PM   #1
CaspianSage
United States
CaspianSage is offline
CaspianSage's Avatar
Arduino Sensors
I was looking at some Arduino sensors for a home project to interface with a PLC 5. Was wondering what is needed to connect them to a dc or TTL input card. I wanted to try a flame sensor first. So what options are there?
Are these 5 volt DO devices?
__________________
Caspian
1+1 = 3 and I never was good at math.
Old February 5th, 2018, 03:19 AM   #2
cardosocea
United Kingdom
cardosocea is offline
Opto-isolator would do what you want... but I'm not sure if you can find them for 24V to 5V reduction. You'd also require the power supply of 5V which would add to the complexity.
Do you have the specs for the flame sensor? If the output is digital, there's a chance that it may take a fair amount of voltage, although you'd have to power it and that is likely to be 5V.
Old February 5th, 2018, 11:44 AM   #3
CaspianSage
United States
For flame sensing looks like this will do nicely- Not going to be used for a safety device, just informative on a water heater.
I think I can de-solder the diode connect wires to it and insert it in a piece of tubing and aim it at the area of the main burner and use another to watch the pilot light. Might even be able to extend the wires long enough to mount the relay module in the PLC Cabinet. Not far from the heater.
They come in 5 and 12 volt models.
https://www.amazon.com/Alloet-Sensor...no+flame+relay
__________________
Caspian
Old February 5th, 2018, 07:12 PM   #4
Geoff White
Australia
Geoff White is offline
You have a PLC5 at home? You should interface it with a PDP-11
Old February 5th, 2018, 08:22 PM   #5
CaspianSage
United States
Wink
Surely you jest.....
Quote:
__________________
Caspian
Old February 6th, 2018, 01:16 AM   #6
spaderkung
Sweden
spaderkung is offline
I think you need to handle voltage converting as a separate interchangable issue. Even if you still find 5v arduinos, most sensors have moved to 3v or lower.
__________________
Jon Bolmstedt, Inspired Automatician.
Old February 6th, 2018, 06:39 AM   #7
Saffa
New Zealand
Saffa is offline
Powering the sensors aside (easily done using cheap voltage regulators like the LM7805 or similar), if it's open collector output then you can just use a pull up resistor and 24V input card.
If you have a bunch of 3 or 5V level signals then I'd interface them to something like this open collector hex buffer.
http://www.ti.com/product/SN7407
If your inputs can be configured for "source" operation then connect directly. If they are only "sink" then add a pull up resistor and invert in logic.
Old February 6th, 2018, 06:48 AM   #8
cardosocea
United Kingdom
Quote:
24 to 5V is a drop that although within the working range is likely to only be possible with really low currents (which could still be enough for this application).
For the same price of the 7805 (plus capacitors and board to connect it) I would go with one of these instead.
https://www.ebay.co.uk/itm/LM2596-DC...0AAOSwTzlZijCJ
No heat to worry about and little assembly/soldering required.
Old February 6th, 2018, 08:33 PM   #9
CaspianSage
United States
I think VCC on these is 5 volts, am I wrong ???? if that is the case all I need is a 5volt PS, pretty easy to come by.
__________________
Caspian
Old February 7th, 2018, 03:06 AM   #10
cardosocea
United Kingdom
Quote:
Not in my experience in industry. But perhaps there are some ready made for panel mount?
Old February 7th, 2018, 03:52 AM   #11
Saffa
New Zealand
Saffa is offline
That looks like a very nice little unit. Would certainly do the trick.
I'd have used a 9V plug pack to power my 5V DC regulator rather than from 24V. I don't have any PLCs at home so it's not normally an issue for me. 24V down to 5V is a bit steep for the 7805, you're right
Old February 7th, 2018, 05:33 AM   #12
TL140
United States
TL140 is offline
I see you want to use a flame sensor, but what is your full application? If using the sensor that CaspianSage mentioned, you could just use an arduino alone. For more inputs and outputs you can use shift registers, and for higher level outputs, have relays. Simpler in some senses, but terrible for maintenance and troubleshooting..
__________________
"The best thing about a boolean is even if you are wrong, you are only off by a bit." -Anonymous
"A good programmer is someone who always looks both ways before crossing a one-way street." -Doug Linder
Old February 7th, 2018, 09:34 AM   #13
CaspianSage
United States
Thanks everyone for jumping in here.
Quote:
All I want is a binary signal - either I have it or I don't A flame relay of some sort will do fine but I want to keep the cost down. As I said in another post this is not for safety or anything critical. Just informative. ie, Main Burner ON or Off
I plan to watch the Pilot Light also and set an annunciator bit if the pilot goes out. A thermocouple that can turn on a relay will work.
These might do it. https://www.ebay.com/itm/BRAND-NEW-G...kAAOSwux5YQDs3
https://www.ebay.com/itm/Lot-Of-2-Om...pe!45801!US!-1
__________________
Caspian
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Arduino to CompactLogix Comms bgtorque LIVE PLC Questions And Answers 9 February 28th, 2017 12:00 PM
serial communication between Siemens PLC and Arduino milan12 LIVE PLC Questions And Answers 13 September 11th, 2015 10:54 AM
Arduino to ControlLogix Ian762 LIVE PLC Questions And Answers 2 June 19th, 2015 02:08 PM
photoelectric sensors light on / dark on Ronnie Sullivan LIVE PLC Questions And Answers 29 May 16th, 2015 05:42 PM
Need to connect 60 pressure sensors to a PLC dbaid LIVE PLC Questions And Answers 10 April 3rd, 2015 08:38 AM
