plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 5th, 2018, 05:52 PM   #1
lesmar96
United States
lesmar96 is offline
reverse three phase to reverse rotation
Hey, this might be a simple question, but I don't think I ever ran into it before.
We all know that on 3ph, any two leads can be swapped to switch the rotation of the motor. Does this not work through a vfd? I suppose with the DC bridge, etc. the output phasing is not necessarily sequential with the input phasing.
At any rate, today I had wired up a panel with a couple vfds and all the motors went the wrong way. Normally, i switch the leads in the terminal box, but since all the motors were going the wrong way, I thought I would just try to switch two leads at the incoming power disconnect. Well that didn't make any difference. Swapped two leads on the line side of the drive and they still went backwards.
Is that normal?
Old February 5th, 2018, 06:03 PM   #2
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
Yes, it's normal. The VFD input section (converter) turns that 3 phase into DC, charges up a capacitor bank like a battery, and then the output section turns it back into 3 phase with no real regard for the input section.. This is great since as long as you keep the wires between the drive and the motor straight, you don't have to worry about something happening to change the phase rotation upstream of the VFD. This is not so great if all your motors turn backwards because it means you have to go move a whole shedload of wires to make them right.
__________________
It's not all the variables I am most concerned with, it's the undiscovered constants.
Old February 5th, 2018, 06:22 PM   #3
daba
United Kingdom
daba is offline
daba's Avatar
You can swap any two phases either at the Input, or Output of the VFD.
This can cause havoc if all the cables in the panel are identified "R, Y, B", people like consistence in the panel, it makes for easier maintenance.
So it might be better to swap the phasing at the motor terminal box, and update the field schematics accordingly.
__________________
___________________________
ControlLogix & SLC Training
a-b train ltd.
abtrain@tiscali.co.uk
www.abtrain.co.uk
tel: 07506 73 9999
nil illegitimi carborundem
Old February 5th, 2018, 06:27 PM   #4
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
Quote:
Uhmm, no. Sorry to disagree, but swapping the input phases will have no effect on a VFD. It will work for a soft starter or for a mechanical motor starter... but not a VFD. You can only change rotation at the output side of the VFD.
Now one other way you can reverse them is through drive programming. That might be easier, but not necessarily the right thing to do.
__________________
Old February 5th, 2018, 06:31 PM   #5
DickDV
United States
DickDV is offline
Great answer, OkiePC. You are exactly correct. As for daba, unfortunately, you are exactly wrong for the reasons OkiePC cites.
Old February 5th, 2018, 06:32 PM   #6
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
Quote:
Daba is sharp as a tack, so I BET he meant input to the motor...
__________________
Old February 5th, 2018, 06:47 PM   #7
daba
United Kingdom
daba is offline
daba's Avatar
Quote:
Yes, I said "Input" to the VFD by mistake, been a long day and didn't think it through.
Perhaps my sharpness is reduced by age, lol
The other considerations I think are valid, though.
__________________
a-b train ltd.
www.abtrain.co.uk
tel: 07506 73 9999
Old February 5th, 2018, 07:02 PM   #8
Aabeck
United States
Aabeck is offline
Aabeck's Avatar
Does the VFD in question have a Run FWD and a Run REV input? Or a direction parameter?
Telling the VFD to run a reversed motor in reverse would put the motion forward.
__________________
Never underestimate the quality of idiots that will be running your machines
http://aabeck.com
Old February 5th, 2018, 07:13 PM   #9
lesmar96
United States
lesmar96 is offline
Yes. the vfd can run in either fwd or rev by terminal command, but I have been taught and also consider it not proper to run a vfd in Rev just to make the motor go the right way because that could cause confusion to some future person.
Old February 5th, 2018, 07:20 PM   #10
daba
United Kingdom
daba is offline
daba's Avatar
Quote:
I don't think it matters. There is absolutely no concept of FWD/REV, versus Clockwise/Anticlockwise, etc.
Some manufacturers go with FWD or Clockwise when looking at the shaft, but there's a few that define FWD or Clockwise when looking from behind the motor.
I'm prepared to be shot down on this, but I don't think there's a "standard", especially when shopping "overseas".
__________________
a-b train ltd.
www.abtrain.co.uk
tel: 07506 73 9999
Old February 5th, 2018, 07:41 PM   #11
lesmar96
United States
lesmar96 is offline
I too stand to be corrected, but I always had the idea that FWD is the way something needs to go. For example, these were on conveyors that always needed to run the same direction and never go the other way. So I would have said that is fwd. Or an air compressor or blowers that needs to go a certain rotation, I would call in forward. But If equipment runs either or at any given time by system instruction, then there really is not fwd or rev per say. That was always my perception.......
Old February 5th, 2018, 07:43 PM   #12
Steve Bailey
United States
Steve Bailey is online now
Steve Bailey's Avatar
Personally, I prefer to change as few drive parameters as possible from their default values. I'll connect the wires so as to make the motor turn in the direction I want it to go at the default direction parameter setting.
Old February 5th, 2018, 09:08 PM   #13
Sydney
Supporting Member
United States
Sydney is offline
Quote:
Logically speaking this makes the most sense in my opinion. When setting up several conveyors we used the default settings of the VFD, than swapped the wires on the output side of the VFD, if necessary. These conveyors were only designed to go in one direction...this was a company standard, and part of our buy-off procedure.
Old February 5th, 2018, 09:41 PM   #14
Ken Roach
United States
Ken Roach is offline
Ken Roach's Avatar
IEC 60034-8 and BS 4999 part 108 specify that the rotation direction is clockwise when viewed from the "Drive-end".
NEMA MG-1 specifies in Section 2.24 that the motor should rotate counter-clockwise when viewed from the non-drive end.
So they're the same, just from inverse definitions.
Go ahead, ask me when International Standards Day is.
Old February 5th, 2018, 10:24 PM   #15
willxfmr
United States
willxfmr is offline
willxfmr's Avatar
If it were me, I would change the rotation at the local disconnect for the motor. This is a pretty standard practice, and should not confuse anyone. Plus it is a lot easier than rewiring the motor.
Bubba.
__________________
“Now will come the nay-sayers with all the reasons why you shouldn't do this. Some of them are teachers, and some of us are doers. Besides, you have got to let the smoke out of this equipment every now and then, or it starts to clog up the chimney.”
~Lancie1
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Mechanical/Material Handling and ISA 88 rlmunoz LIVE PLC Questions And Answers 7 October 11th, 2018 09:45 AM
3 phase motor rotation allscott LIVE PLC Questions And Answers 16 December 16th, 2009 10:59 PM
What do you call this voltage joeparrish LIVE PLC Questions And Answers 52 October 15th, 2008 03:20 AM
Reverse Rotation on 120VAC Motor smcmanus LIVE PLC Questions And Answers 8 November 15th, 2007 11:22 AM
Phase rotation and motor rotation testers leitmotif LIVE PLC Questions And Answers 2 August 14th, 2005 09:04 PM
