plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 5th, 2018, 05:58 PM   #1
lesmar96
United States
lesmar96 is offline
allen bradley e1 plus
I have a customer that is running a grain auger of an AB motor starter. The overload is an Allen-Bradley E1 plus with a range of 5.4-27A. The motor FLA is 4.3 and the overload is set the whole way down. Well the issue is they keep burning up motors from overloading or stalling the auger. Why doesn't this overload trip out?
There is a "trip" pot that I could adjust, but I wasn't sure what that did?
Please advise.
Old February 5th, 2018, 06:08 PM   #2
jaden
United States
jaden is offline
By your numbers, the Overload's minimum is about 25% too high to adequately protect the motor. You need a different Overload. Augers may overload if at a steep angle and started with grain in them. Running them empty before stopping makes starting up much easier.
Old February 5th, 2018, 06:08 PM   #3
sbaum
Canada
sbaum is offline
Electonic overloads must be set to actual motor FLA (for typical motor SF. Check the overload documentation) so that overload is sized wrong.
But the real problem is the overload isn't even wired into the control circuit. The NC contact on 95 & 96 must interupt the coil.
Old February 5th, 2018, 06:12 PM   #4
Ken Roach
United States
Ken Roach is offline
Ken Roach's Avatar
Here's the User Manual: Link
That little "trip" rotary device is a manual trip trigger.
The dial should be set for Full Load Amperes, as the trip setting is 120% of the dial setting.
With the dial turned down all the way, the trip setting is still 1.20 x 5.7 = 6.84 amperes.
Have you measured how many amps the motor pulls with a stalled rotor ?
Old February 5th, 2018, 06:14 PM   #5
Ken Roach
United States
Ken Roach's Avatar
Yeah, that will do it. Betcha it was removed because the auger kept tripping out.
Edit: It doesn't look to me like any of the overloads are wired correctly. Turning the manual trip device or pressing the Test button will prove right away whether they're wired correctly or not.
Old February 5th, 2018, 06:22 PM   #6
sbaum
Canada
sbaum is offline
I bet it was never wired right. The picture is a bit dark but it looks like the overloads on either side don't have their overloads connecting either.
Old February 5th, 2018, 07:19 PM   #7
lesmar96
United States
lesmar96 is offline
Yes. you are right. I did not build this panel, I was called in for other reasons and I agree it is not wired right because none of the aux are wired into the appropriate control circuits.
Thanks for the manual, Ken Roach, I was not familiar with this overload was having a hard time sorting through all the documentation available.
All though it is not wired correctly, it shouldn't have made the motor burn out unless the overload is auto resetting?? and it kept automatically trying??
Old February 5th, 2018, 08:09 PM   #8
jaden
United States
jaden is offline
The overload condition is a mechanical overload from the auger, but without the Overload properly sized and wired, the starter will not shut down to protect the motor.
Old February 5th, 2018, 08:37 PM   #9
jraef
United States
jraef is offline
jraef's Avatar
If the aux contact is not wired to the contactor coil, how is the OL relay going to cause the motor to disconnect? It doesn't have any power contacts, it's just a "sensor" and the aux contacts drop out the coil of the contactor to stop current flowing to the motor. Without that, it could be tripping all day long and nothing else will happen.
Whomever built that system was a nincompoop...
And as was said earlier, even IF the contacts were wired in correctly, the OL relay is the wrong size for that motor, you cannot turn the dial down low enough to protect it.
Old February 5th, 2018, 11:16 PM   #10
jaden
United States
jaden is offline
jraef, I think you mean Overload Contact (95,96) wired into the coil, not the aux.
Old February 6th, 2018, 08:15 AM   #11
lesmar96
United States
lesmar96 is offline
OK. This all makes sense to me. I was thinking this was a bimetallic relay that would actually disconnect the motor upon a trip condition, but I realize that is not the truth with this electronic one. I assume whoever built this panel did not realize what they were putting in.
Old February 6th, 2018, 08:39 AM   #12
jaden
United States
jaden is offline
Bi-metal and Eutectic Alloy overloads also do not open the motor leads. They too have a NC contact that opens to de-energize the starter coil.
Old February 6th, 2018, 08:44 AM   #13
lesmar96
United States
lesmar96 is offline
Thanks for the clarification.
Old February 6th, 2018, 06:07 PM   #14
jaden
United States
jaden is offline
You're welcome. I teach this stuff part time, so I have to be careful not to get too picky or go into excessive detail.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Eaton ELC- Which Allen Bradley is most comparable? zielker LIVE PLC Questions And Answers 6 June 29th, 2015 04:01 PM
Communication possibilities between Bachmann controller and Allen Bradley PLC KevinQ LIVE PLC Questions And Answers 0 October 16th, 2014 05:51 AM
allen bradley to siemens irondesk40 LIVE PLC Questions And Answers 6 February 16th, 2014 11:34 AM
Allen Bradley for temperature control again irondesk40 LIVE PLC Questions And Answers 12 November 15th, 2013 03:01 PM
Allen Bradley HMI Chopperman LIVE PLC Questions And Answers 13 June 7th, 2012 08:35 AM
