plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 5th, 2018, 06:11 PM   #1
Jim_cz
Australia
Jim_cz is offline
Help please with programming a timer value that depends on a conveyor speed
I have a conveyor whose speed varies between 20 and 50Hz through a PLC (HMI). I need to program a code with a timer whose value will vary between 10 and 4 seconds inversely proportionally to the speed of the conveyor. That means, when the speed will be 20Hz the timer will need to start timing from 10s and when the speed will be 50Hz the timer needs to have 4s.
Any tip please how I can program it with Omron PLC?
Old February 5th, 2018, 06:44 PM   #2
daba
United Kingdom
daba is offline
daba's Avatar
It is simple maths you could "roll your own".
I don't know the Omron instruction set, is there something like a "Scale with Parameters" or just a "Scale" instruction.
Most (from other manufacturers) will work with inverse parameters.
__________________
___________________________
ControlLogix & SLC Training
a-b train ltd.
abtrain@tiscali.co.uk
www.abtrain.co.uk
tel: 07506 73 9999
nil illegitimi carborundem
Old February 5th, 2018, 07:02 PM   #3
JaxGTO
United States
JaxGTO is offline
If its linear then just do scaling where 20-50=10-4. Lookup a standard scale block online, in AB land it's a SCP (Scale with Parameters) instruction. But the math is simple.
Old February 5th, 2018, 11:04 PM   #4
bernie_carlton
United States
bernie_carlton is online now
bernie_carlton's Avatar
Or just divide 200 by the hz.
__________________
Controlling outputs is the PLC's way of getting its inputs to change.
www.thePLCguy.com
Old February 6th, 2018, 12:47 PM   #5
Dirt
Sweden
Dirt is offline
Quote:
+1
And maybe add limits to not be less than 4 or more than 10?
Old February 6th, 2018, 10:46 PM   #6
Jim_cz
Australia
Jim_cz is offline
Thanks guys, you've given my invaluable advice. I should be able to pull it off now.
Old February 7th, 2018, 10:05 AM   #7
bernie_carlton
United States
Just as a note, the Scale With Parameters suggestions probably would not have worked since this is an inverse relationship, as Jim_cz noted, and not a linear one.
__________________
www.thePLCguy.com
Old February 7th, 2018, 05:35 PM   #8
Geoff White
Australia
Geoff White is offline
Here you go.
Old February 8th, 2018, 06:31 AM   #9
daba
United Kingdom
daba is offline
daba's Avatar
Quote:
Originally Posted by Geoff White View Post
Here you go.
It's an Omron PLC, Geoff....
__________________
a-b train ltd.
www.abtrain.co.uk
tel: 07506 73 9999
Old February 8th, 2018, 06:41 AM   #10
daba
United Kingdom
daba is offline
daba's Avatar
It would still be linear, Bernie, even though it is "inverted".
Also I would suggest that the math involved with "rolling your own" SCP (if you had to), would most likely work in any processor that can handle negative numbers. Certainly works fine in Allen-Bradley controllers.
__________________
a-b train ltd.
www.abtrain.co.uk
tel: 07506 73 9999
Old February 8th, 2018, 08:27 AM   #11
gclshortt
Canada
gclshortt is offline
gclshortt's Avatar
http://www.plctalk.net/qanda/showthread.php?t=97825
The above will help you with the Omron scale instruction.
Use the output as the timer set value. (SV)
Regards,
__________________
Garry
https://www.accautomation.ca
Connect with us on Facebook: facebook.com/accautomation/
Old February 8th, 2018, 10:04 AM   #12
bernie_carlton
United States
Re: it's still linear, plot the result of y = 200/x with x varying from 20 to 50. Then check the results provided by a scale instruction.
__________________
www.thePLCguy.com
Old February 8th, 2018, 11:20 AM   #13
Dirt
Sweden
Dirt is offline
I think you missed the words "inversely proportional" in the topic?
If it'd be linear (directly proportional), it would look like this
y=-0.2x+14
x=Hz
y=seconds
inversely proportional isn't linear:
y=200/x
Old February 8th, 2018, 11:37 AM   #14
bernie_carlton
United States
The OP was obviously looking for a timer preset such that the conveyor would travel the same distance as timed by the timer for various speeds. Check for that relationship with the output from a scale function. Multiply the output by the input for all the settings and see if you get a constant.
__________________
www.thePLCguy.com
Old February 8th, 2018, 12:02 PM   #15
daba
United Kingdom
daba is offline
daba's Avatar
y=-0.2x+14
x=Hz
y=seconds
y=200/x
Of course it is.....
I didn't miss anything.
"Linear" is to do with the scale factor value, which can be positive or negative, and if that scale remains constant, then the relationship is "linear". If the scaling factor changes in any way, the relationship becomes "non-linear".
Linear means "straight-line" and a straight line is produced if m is kept a constant in the scaling equation y = mx + c
If m is kept a constant, it can be positive, to give "proportional", or negative, to give "inversely proportional".
The "proportional" part of the description is the scaling, and if you don't say "inversely" y increases as x increases. When you add "inversely", y will decrease as x increases.
Proportional and Inversely Proportional are both Linear.
__________________
a-b train ltd.
www.abtrain.co.uk
tel: 07506 73 9999
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Reset Timer Dilemma dskplc LIVE PLC Questions And Answers 20 December 2nd, 2014 12:06 PM
AB SLC-500 Beginner Questions 2k1Toaster LIVE PLC Questions And Answers 37 April 15th, 2014 06:05 PM
programming a timer for a dosing pump oyster LIVE PLC Questions And Answers 6 November 24th, 2006 06:59 AM
Good programming practice Rhonda LIVE PLC Questions And Answers 83 August 17th, 2006 03:52 PM
Automation Direct DL05 problem david bron LIVE PLC Questions And Answers 16 February 2nd, 2004 09:52 PM
