Mitsubishi PLC via Router
PFrog
Apr 2011
Ohio
83
Hello,
I am attempting to bring a Mitsubishi Q PLC up on the network via the PLC Ethernet port. Currently all IP's on these local networks are the same (some are incredibly difficult to change), and I am using a 1783 NATR module to do some ip translating. Ports are blocked by default on the NATR module. I am unsure of the specific port address I should be using in the NATR module. In addition, I am not sure if anything else needs to be configured on the PLC side other than the gateway (NATR local IP address).
It appears it says you are unable to use the "find CPU" option if a router is in use. Directly keying in the address does not work either. I've tried a few port options I've found online, and they did not work.
I am able to remote into a computer on this network (private/public side), and connect to the PLC only on the private side.
Any ideas?
Thanks,
Keith
Hello everybody! I found option for creating communication with Q series via python. But can't find any tips for connecting with PLC FX series...
5,369
Looking for Socket TCP/IP communications program examples for Mitsubishi PLC iQ-R R04CPU using GX Works3, to compliment the Mitsubishi Ethernet...
6,359
Is there anybody that can help me figure out what I am doing wrong? I am trying to connect to customer's machines that have Win 7 PC's for the...
1,344
Hi there I have tried every resource I could to get my lap top connected to A series mitsubishi via MD11 programming port. There is a Proface...
2,154
hi evryone there is a problem like this. i wanted to connect mitsubishi plc with simovert drive via rs485. it seems very simple cause mechanism...
1,812
