Your experience with switches on Profinet?
Lord Farquaad
Feb 2015
Noord Holland
35
I have a project that will have S7-400 PLC as the main PLCs, but also quite a few S7-300 PLCs from various vendors. MCCs will be on Profinet, but not sure if it will be Simocodes or ABB UMCs. The UMCs seem to be the cheaper option by quite a bit. Should be about 450 motors in total. Field IO will be AS-i from IFM, 17 dual masters.
As price is king on this job, I need to save money wherever I can. My first choice would be Scalance switches all over, in the main fibre rings and the MCC device rings. Apart from Scalance, I am also considering solutions from Hirschmann, Westermo and Moxa. Obviously they have to be Profinet certified.
I have worked extensively with Hirschmann switches on a Rockwell pant, and Moxa on Ethernet. Would you guys mind sharing your experience with these brands on Profinet, or maybe even other brands I never considered.
Price is the main criteria, but coupled to that, is service and support. This is where Siemens fall off the bus. Once the purchase have been made, you are on your own lately.
@ All: what is your best guess on a potential range in increase in efficiency in % (i.e. saved programming hours, greater output, etc.) when...
349
Hey guys, has anyone worked with any type of Keyence PLC and could share their experience with it? Vendor showed me camera footage reply of a work...
1,164
Hi, I have a customer inquiring about an automation product called uSwitch. I can read all the literature but working experience is always...
605
Hi to all, does anyone have experience with using Codesys software for PLC programming? (https://www.codesys.us/) What I can find out is that...
1,116
Hi all, I am experienced with Rockwell by have recently encountered a Bosch PLC. It’s an IndraControls XM21 V14. I installed the software and...
773
