plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 7th, 2018, 02:29 AM   #1
Kaktus33
Poland
Kaktus33 is offline
Can't establish communication
Hi. I have a PanelView Plus 600 panel and a Honeywell C200 controller. The task is to connect them for joint work. FTView Studio 6.10 software is installed to work with the panel, but RSLinx Enterprise does not define a Honeywell controller. There is RSLinx Classic for which EDS files for Honeywell equipment are installed. It sees and recognizes the controller. But there is no way to put these EDS files in RSLinx Enterprise. Any ideas how to get out of this situation?
Old February 7th, 2018, 04:49 PM   #2
ASF
Australia
ASF is offline
Welcome to the forum!
To use a third-party controller with a Panelview Plus, you need to use the included Kepware OPC server.
You will need to flash the firmware on the HMI, and when you do, select the relevant Kepware drivers to be loaded onto the hardware. Then you'll need to configure the tags in Kepware to be used in FTView Studio.
That's the short version - now that you know what to look for, give it a try and let us know if you need more help!
Old February 8th, 2018, 01:34 AM   #3
Kaktus33
Poland
Kaktus33 is offline
Thanks.
I thought about it, but in the firmware for HMI there are no drivers for the Honeywell C200 controller and Kepware Enterprise also does not contain the necessary drivers. The problem is that this equipment is not supported and how this can be changed is not clear.
Old February 8th, 2018, 11:02 AM   #4
Ken Roach
United States
Ken Roach is offline
Ken Roach's Avatar
Honeywell C200 controllers share some hardware with Rockwell Automation ControlLogix because of the joint venture for process control applications more than fifteen years ago. Rockwell called it ProcessLogix, Honeywell called it PlantScape.
I don't know if FactoryTalk View (and thus the PanelView Plus 600) will work with any of the Honeywell operating system objects.
I recommend researching support in the C200 controller for Modbus/TCP protocol support. The PV+600 does support Modbus/TCP via the Kepware driver suite.
Old February 9th, 2018, 01:31 AM   #5
Kaktus33
Poland
Kaktus33 is offline
Thanks, I'll try to work in this direction.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
PanelView Plus ---> SLC L551 Ethernet Communication Issues celichi LIVE PLC Questions And Answers 17 May 3rd, 2016 01:40 PM
How to establish communication between MVI69-GSC with Parker HPC Servo drive AB2005 LIVE PLC Questions And Answers 0 September 17th, 2012 08:58 AM
S7 313C communication port repair sttchui LIVE PLC Questions And Answers 1 March 25th, 2008 06:14 AM
How to establish communication between SLc 5/03 and multiple Modbus devices M. HASSAN LIVE PLC Questions And Answers 6 August 25th, 2007 05:14 PM
OPC Communication ikon2018 LIVE PLC Questions And Answers 0 June 21st, 2005 07:47 AM
